compile problem on v0.9.5 .
younger
Postby younger » Wed Jan 28, 2015 5:29 pm
Hi Espressif:
I just want to add smartconfig(smartconfig_start) into the IOT_demo,but it compiles with a problem:
make: Warning: File `.output/eagle/debug/image/eagle.app.v6.out' has modification time 14 s in the future
xtensa-lx106-elf-gcc  -L../lib -nostdlib -T../ld/eagle.app.v6.new.512.app1.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lmain -ljson -lssl -lupgrade -lsmartconfig user/.output/eagle/debug/lib/libuser.a driver/.output/eagle/debug/lib/libdriver.a -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out
/opt/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .output/eagle/debug/image/eagle.app.v6.out section `.irom0.text' will not fit in region `irom0_0_seg'
But if I compile without "user_esp_platform_init();" and "user_webserver_init(SERVER_PORT);" , it will be OK. why? :shock:
Re: compile problem on v0.9.5 .
Postby Her Mary » Thu Jan 29, 2015 11:13 am
:lol:
That means your source code is too large to fit in .. try to compile as 1024KB flash , and use a 1024KB flash..
younger
Postby younger » Thu Jan 29, 2015 1:37 pm
Her Majesty wrote::lol:
No ,I use "make COMPILE=gcc BOOT=new APP=1 FLASH=1024" , it also compiles error.
user_main.rar
(1.02 KiB) Downloaded 792 times
Postby ESP_Faye » Thu Jan 29, 2015 3:44 pm
Yes,log “section `.irom0.text' will not fit in region `irom0_0_seg'” means your source code is too large to fit in
1、you can compile it as 1024KB flash and use 1024KB flash
2、delete some useless source code to make it fit in
:oops:
If you need to compile as 1024 new,please unzip the attachment and replace them in \esp_iot_sdk_v0.9.5\ld
sorry for the inconvenience.
ld_1024.zip
(2.82 KiB) Downloaded 650 times
younger
Postby younger » Thu Jan 29, 2015 4:16 pm
Espressif_Faye wrote:Yes,log “section `.irom0.text' will not fit in region `irom0_0_seg'” means your source code is too large to fit in
:oops:
Hi Espressif:
yes,if i use 1024kb compile ,it will be OK.
But the compile result: user1.1024.new.bin just 221kB, in 512kB flash ,the user1 bin size could be 236kB ,remain 15kb !
why ? :cry:
younger
Postby younger » Thu Jan 29, 2015 4:58 pm
OH, I have found it.
The .irom0.text size is 0x2e2a4, and the limit is 0x2B000, so compile error.
So I just want to know what " .irom0.text " contains ?
:idea:
Postby ESP_Faye » Fri Jan 30, 2015 9:50 am
methods with "ICACHE_FLASH_ATTR" in irom0_0_seg
methods without "ICACHE_FLASH_ATTR" in iram1_0_seg
You could try this http://bbs.espressif.com/viewtopic.php?f=10&t=166
Or try to remove "ICACHE_FLASH_ATTR" from some methods, so they will be compiled to iram1_0_seg area.
