[Resolved] espconn disconnect callback not received
esp03madness
Postby esp03madness » Sun Jan 10, 2016 11:38 pm
Hello friends,
I having some problems using espconn with RTOS SDK 1.3. I am able to open a TCP connection as a client - connect, receive data, stay idle. When remote closes connection (due to timeout), I do not get a disconnection callback.
//create tcp connection like this
connection.type=ESPCONN_TCP;
connection.state=ESPCONN_NONE;
connection.proto.tcp=&tcp;
tcp.local_port = espconn_port();
tcp.remote_port = 1234;
memcpy(&tcp.remote_ip, &ip, 4);
espconn_regist_connectcb(&connection, network_connected_cb);         //called
espconn_regist_disconcb(&connection, network_disconnected_cb);       //not called
espconn_regist_reconcb(&connection, network_reconnected_cb);         //not called
espconn_regist_recvcb(&connection, network_receive_cb);              //called
espconn_connect(&connection);
Here's what I see in the console
espconn_client_connect, regist espconn_client_recv
network_receive_cb
RX: blah blah blah
//*** some time passes, remote closes connection due to inactivity ***
espconn_client_recv, espconn_client_close, err:0, p:      0
espconn_client_close, close
//*** network_disconnected_cb should be here, but it isn't ***
Re: espconn disconnect callback not received
Postby ESP_Faye » Mon Jan 11, 2016 2:20 pm
Please call "espconn_init();" in the user_init. And try it again.
esp03madness
Postby esp03madness » Mon Jan 11, 2016 5:35 pm
That worked, thank you.
Why is espconn_init() not part of the espconn.h header file?
Re: [Resolved] espconn disconnect callback not received
Postby ESP_Faye » Tue Jan 12, 2016 10:34 am
Sorry that we missed it in the espconn.h. It will be added in the next RTOS SDK.
Sorry for the inconvenience.
Users browsing this forum: No registered users and 193 guests
