WiFi Stability issues with non-os SDK 1.4 and 1.5
Postby DavidDPD » Wed Jan 13, 2016 4:07 am
I finally resolved my issues last night with SDK 1.5.0 and the ESP-12E boards, by rolling back to 1.3.0. In 1.5.0, when the ESP-12E is in station mode, and connects to the SSID, within in 10-15 seconds after boot, it drops of the network (stops responding to pings), and starts reporting bcn_timeouts. Eventually, it dissociate from the access point, and reconnect. After which it seems to be pretty stable.
The Access point is on a clean channel (despite having a lot of 2.4 GHz APs in the area), Signal is running between -30 to -40 dBm, and Noise is running ~ -95dBm (on the access point).
The AP is TP-Link TL-WDR3600 v1, running OpenWrt Chaos Calmer 15.05 / LuCI (git-15.248.30277-3836b45).
Rolling back to SDK 1.3.0 avoids this issue all together and seems significantly more stable.
EDIT : Additionally - ESP Save With Protect doesn't seem to work correctly on 1.5.0 after first reboot.
I would love to help debug this, however since the SDK libraries seems to be closed, and no additional debugging functions, I'm at a loss what else to do.
Re: WiFi Stability issues with non-os SDK 1.4 and 1.5
Postby ESP_Faye » Wed Jan 13, 2016 2:10 pm
Sorry that I do not really understand your test steps. Is it as below ?
Step 1. ESP8266 runs as station-only mode.
Step 2. ESP8266 connects to router "TL-WDR3600".
Step 3. Do nothing, just wait a while. ESP8266 will disconnects to the router ? At this time, could other stations connect to the router ?
Please correct me if I misunderstood it. Thanks.
Postby DavidDPD » Fri Jan 15, 2016 2:01 am
with user_config.h :
#define STA_DEFAULT_NETWORK 1
#define SSID "demo"
#define SSID_PASSWORD "demo1234"
#define CONFIG_AP_SWITCH 0
#define CONFIG_STA_SWITCH 1
Here is a video screen capture ( duration: 3min 30sec ). This is constant, reproducible behavior with SDK 1.5.0. SDK 1.3.0 does not exhibit this behavior. However, in 1.5.0, after this initial disconnect, it seems to stay connected.
- https://youtu.be/iH1epQXynIE
.r...lØrß.#.ânÀ..à....ì.p|.ìx.ÇÜä.p...ònnä.Ä;ònÄä...bç$r..r..pònàÃÜ..àÇÀl......bÀ.nâãnÀä.À.8..ònnî.ÄÁ.l`.ü.Ü#nÀ.;....nrß;.ÄÀ.?ì;..pònàÃÜ..àrÇ.âÜ......p..pÜ<.Ä....p..ònnî.ÄØ..r...#nÀ..r....nrß;.ÄÀ.?.rÜ;.pònàÃÜ..àrÇ.âÜ......p..pÜ<.ÄÃ..âl..bÄ>~ònî.Äð..r...Ü#nÀ.r....nrß;.ÄÀ.?.Ü;..rÛnÀ.à.Ü.`.üdon't use rtc mem data
r..¦ÿ[DEBUG][../dpdChatFabric/cfConfig.c:_cfConfigRead:161] Starting Config Read, fromStr = 0
[DEBUG][../util/util.c:_cfConfigRead:166] Config String, RAM, preload :: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[DEBUG][../util/util.c:_cfConfigRead:174] Config String, RAM, post-load :: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[DEBUG][../dpdChatFabric/cfConfig.c:_cfConfigRead:185] ========== NO CONFIGUTATION DATA FOUND : 00 a5 ==========
[DEBUG][../util/util.c:cfConfigWrite:415] Config String: a5000000 000b0000 00000c00 00000105 00000000 00000000 00000000 00000000 06322413 ffe02c11 faae7718 fe34a2e0 5b2f0000 00020f00 00000012 00000001 15000000 01180000 00011300 00000014 00000000 230264a8 c02400ff ffff2502 64a8c026 0264a8c0 270264a8 c0280264 a8c01901 fa10ac1a 00ffffff 1b01fa10 ac1c01fa 10ac1d01 fa10ac29 00000000 00000000 00000000 00000000 2a000000 00000000 00000000 00000000 002b0000 00000000 00000000 00000000 00002c00 00000000 00000000 00000000 0000002d 00000000 00000000 00000000 00000000 2e000000 00000000 00000000 00000000 001e0000 00000000 00000000 00000000 00001f00 00000000 00000000 00000000 00000020 00000000 00000000 00000000 00000000 21000000 00000000 00000000 00000000 00220000 00000000 00000000 00000000 00000e63 662d3138 66653a33 3461323a 65303562 00000000 00000000 00000000 00000010 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 11657370 38323636 2164656d 6f000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00166465 6d6f0000 00000000 00000000 00000000 00000000 00000000 00000000 00001764 656d6f31 32333400 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[DEBUG][../util/util.c:_createKeyString:473] Keys Public: 37434e22 19b40455 a6b6ba88 da84e342 422e2e65 a17cca4b d3fd0485 efcd5254
[DEBUG][../util/util.c:_createKeyString:475] Keys Private: a302d272 fe9670c8 9f8988cb 1018190b 63ee2c2c 9679c676 71ea66e2 88500b82
[DEBUG][../util/util.c:cfConfigWrite:419] Keys String: 0137434e 2219b404 55a6b6ba 88da84e3 42422e2e 65a17cca 4bd3fd04 85efcd52 5402a302 d272fe96 70c89f89 88cb1018 190b63ee 2c2c9679 c67671ea 66e28850 0b82
[DEBUG][../util/util.c:cfConfigWrite:429] Config String, RAM, presave :: a5000000 000b0000 00000c00 00000105 00000000 00000000 00000000 00000000
[DEBUG][../dpdChatFabric/cfConfig.c:cfConfigWrite:434] ESP Save With Protect - SUCCESS.
[DEBUG][../util/util.c:cfConfigWrite:438] Config String, RAM, postsave :: a5000000 000b0000 00000c00 00000105 00000000 00000000 00000000 00000000
[DEBUG][user/user_main.c:user_init_stage2:516] UUID0 : 00000000-0000-0000-0000-000000000000
[DEBUG][user/user_main.c:user_init_stage2:519] UUID0 : 322413ff-e02c-11fa-ae77-18fe34a2e05b
[DEBUG][user/user_main.c:gpioInitFromConfig:163] === Setting: 0 Top Outlet 0 12
[DEBUG][user/user_main.c:gpioInitFromConfig:163] === Setting: 1 Bottom Outlet 0 13
mode : sta(18:fe:34:a2:e0:5b)
add if0
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with demo, channel 4
dhcp client start...
[DEBUG][espChatFabric/esp-cf-wifi.c:espCfWiFi_callBack:43] connect to ssid demo, channel 4
ip:192.168.1.229,mask:255.255.255.0,gw:192.168.1.1
[DEBUG][espChatFabric/esp-cf-wifi.c:espCfWiFi_callBack:66] ip:192.168.1.229,mask:255.255.255.0,gw:192.168.1.1
[DEBUG][driver/ntp.c:ntp_get_time:118] starting
[DEBUG][driver/ntp.c:ntp_get_time:133] ntp array set
[DEBUG][driver/ntp.c:ntp_get_time:155] selecting Ip address
[DEBUG][driver/ntp.c:ntp_get_time:160] memcpy ip
[DEBUG][driver/ntp.c:ntp_get_time:167] selected
[DEBUG][driver/ntp.c:ntp_get_time:183] return
[DEBUG][espChatFabric/esp-cf-mdns.c:espCfMdns:29] station_if ip
[DEBUG][espChatFabric/esp-cf-mdns.c:espCfMdns:34] Setting Up mDNS; ip:192.168.1.229
host_name = cf-18fe:34a2:e05b
server_name = _exp1._tcp.local
[DEBUG][driver/ntp.c:ntp_udp_recv:79] start
[DEBUG][driver/ntp.c:ntp_udp_recv:114] return
pm open,type:2 0
bcn_timout,ap_probe_send_start
[DEBUG][user/user_main.c:clock_loop:339] 1452793440
[DEBUG][user/user_main.c:clock_loop:339] 1452793500
[DEBUG][user/user_main.c:clock_loop:339] 1452793560
ap_probe_send over, rest wifi status to disassoc
state: 5 -> 0 (1)
rm 0
pm close 7
[DEBUG][espChatFabric/esp-cf-wifi.c:espCfWiFi_callBack:52] disconnect from ssid demo, reason 200
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
[DEBUG][espChatFabric/esp-cf-mdns.c:espCfMdns:14] Closing mDNS (1)
pm open,type:2 0
.[DEBUG][user/user_main.c:clock_loop:339] 1452793620
[DEBUG][user/user_main.c:clock_loop:339] 1452793680
[DEBUG][user/user_main.c:clock_loop:339] 1452793740
[DEBUG][user/user_main.c:clock_loop:339] 1452793800
[DEBUG][user/user_main.c:clock_loop:339] 1452793860
[DEBUG][user/user_main.c:clock_loop:339] 1452793920
[DEBUG][user/user_main.c:clock_loop:339] 1452793980
[DEBUG][user/user_main.c:clock_loop:339] 1452794040
Postby ESP_Faye » Wed Jan 20, 2016 4:58 pm
Please have a try with the latest ESP8266_NONOS_SDK_V1.5.1.
Postby cranphin » Mon May 23, 2016 11:35 pm
Any luck resolving this? :)
It feels like it might (mayby!) touch the issue I'm having: viewtopic.php?f=66&t=2203
I have sometimes wifi, sometimes not, using 1.4.0 and any higher firmware on a ESP-12E, works fine on 1.3.0 and lower.
Cheers!
Postby DarkSide » Tue Jul 19, 2016 3:36 pm
Postby DavidDPD » Sun Sep 11, 2016 2:37 am
2.0.0 is completely unusable ... it won't even boot code ... just endless garbage on the UART out.
@ESP_Faye - can someone look into this ? Seems like a pretty wide issue.
Would really LOVE if you guys would open source all the code in the libraries - so the community can help debug and fix issues like this.
Postby DavidDPD » Mon Sep 12, 2016 11:51 am
If I switch channels of the AP without a reboot of the ESP8266 (ESP is in STATION mode only) - in SDK 1.5.4 ... it reconnects and is then stable. Then if I restart the ESP, I get into the ban_timout loop again.
Serial transcript :
r...lØrß.#.ânÀ.à....ì.p<ß.ì8.ßÇÜä.p...ònnä.Ä;ònÄÜä...bç$r..r..pònàÜ...àÇÀl......b.nâãnÀÄ.lØ..p..ònnî.ÄÁ.l`.ü.Ü#nÀ.;....nrß;.ÄÀ.?.Ü;.pònàÃÜ..àrÇ.âÜ......p..pÜ<.ÄÄ..8..ònnî.ÄÈ..r...Ü#nÀ.r....nrß;.ÄÀ.?8r..pònàÃÜ...àrÇ.âÜ......p..pÜ<.ÄÃ..â..à.bÀľ~ònî.ÄÀ..r...Ü#nÀ$l`.ä8`rn|nÀ..à.8r...rßÛnÀ..à.8r..âÜçÉ8.ò. ±..ì.r..âÜçÉ8ì.ò. ±....r..âÜçI8.û.0±..l.r..r..Nÿ[DEBUG][../dpdChatFabric/cfConfig.c:_cfConfigRead:161] Starting Config Read, fromStr = 0
[DEBUG][../util/util.c:_cfConfigRead:174] Config String, RAM, post-load :: a5000000 000b0000 00000c00 00000105 00000000 00000000 00000000 00000000
[DEBUG][../util/util.c:cfConfigWrite:415] Config String: a5000000 000b0000 00000c00 00000105 00000000 00000000 00000000 00000000 06291642 80476b11 81800d60 01940924 662f0000 00020f00 00000012 00000001 15000000 01180000 00011300 00000014 00000000 230264a8 c02400ff ffff2502 64a8c026 0264a8c0 270264a8 c0280264 a8c01901 fa10ac1a 00ffffff 1b01fa10 ac1c01fa 10ac1d01 fa10ac29 00000000 00000000 00000000 00000000 2a000000 00000000 00000000 00000000 002b0000 00000000 00000000 00000000 00002c00 00000000 00000000 00000000 0000002d 00000000 00000000 00000000 00000000 2e000000 00000000 00000000 00000000 001e0000 00000000 00000000 00000000 00001f00 00000000 00000000 00000000 00000020 00000000 00000000 00000000 00000000 21000000 00000000 00000000 00000000 00220000 00000000 00000000 00000000 00000e63 662d3630 30313a39 3430393a 32343636 00000000 00000000 00000000 00000010 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 11657370 38323636 2164656d 6f000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00166465 6d6f0000 00000000 00000000 00000000 00000000 00000000 00000000 00001764 656d6f31 32333400 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[DEBUG][../util/util.c:_createKeyString:473] Keys Public: bc902653 82ef9cc1 6350f4e1 c2605149 88bb1cde 1af2f45d 3207952c 831f6455
[DEBUG][../util/util.c:_createKeyString:475] Keys Private: 67de4089 401979b7 a6a965c4 81c5e202 c8cbb466 96559080 e639c0cb 3fafc1c7
[DEBUG][../util/util.c:cfConfigWrite:419] Keys String: 01bc9026 5382ef9c c16350f4 e1c26051 4988bb1c de1af2f4 5d320795 2c831f64 550267de 40894019 79b7a6a9 65c481c5 e202c8cb b4669655 9080e639 c0cb3faf c1c7
[DEBUG][user/user_main.c:user_init_stage2:653] reading pair config
[DEBUG][../dpdChatFabric/cfPairConfig.c:cfPairRead:237] Got Length as f1 6f000000 2159
[DEBUG][../dpdChatFabric/cfPairConfig.c:cfPairRead:296] ========>: cfPairRead
[DEBUG][../util/util.c:cfPairRead:297] shared key: af973adf ead4543a f6e878c6 70bc48b4 8791e1ef be38105c f894d4d0 492c9e60
[DEBUG][../util/util.c:cfPairRead:298] nonce: 0d9527c8 8a647a96
[DEBUG][../util/util.c:cfPairRead:299] mynonce: 0419e5c5 87c146d0
[DEBUG][user/user_main.c:user_init_stage2:666] UUID0 : 00000000-0000-0000-0000-000000000000
[DEBUG][user/user_main.c:user_init_stage2:669] UUID0 : 29164280-476b-1181-800d-600194092466
[DEBUG][user/user_main.c:gpioInitFromConfig:202] === Setting: 0 Top Outlet 0 12
[DEBUG][user/user_main.c:gpioInitFromConfig:202] === Setting: 1 Bottom Outlet 0 13
[DEBUG][user/user_main.c:gpioInitFromConfig:202] === Setting: 2 yellow14 0 14
[DEBUG][user/user_main.c:gpioInitFromConfig:202] === Setting: 3 yellow16 0 16
mode : sta(60:01:94:09:24:66)
add if0
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with demo, channel 1
[DEBUG][espChatFabric/esp-cf-wifi.c:espCfWiFi_callBack:43] connect to ssid demo, channel 1
ip:192.168.1.231,mask:255.255.255.0,gw:192.168.1.1
[DEBUG][espChatFabric/esp-cf-wifi.c:espCfWiFi_callBack:66] ip:192.168.1.231,mask:255.255.255.0,gw:192.168.1.1
[DEBUG][espChatFabric/esp-cf-mdns.c:espCfMdns:34] Setting Up mDNS; ip:192.168.1.231
host_name = cf-6001:9409:2466
pm open,type:2 0
state: 5 -> 0 (1)
rm 0
pm close 7
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
[DEBUG][user/user_main.c:clock_loop:380] 1473651540
[DEBUG][user/user_main.c:adcBultin:552] [perUnit: 00.000] ADC0: 006e : volts 00.000
[DEBUG][driver/ntp.c:ntp_udp_timeout:58] start
[DEBUG][driver/ntp.c:ntp_udp_timeout:75] return
[DEBUG][user/user_main.c:ntpTimer_loop:356] [NTP] Timeout ; from server 208.75.88.4
pm open,type:2 0
state: 5 -> 2 (7c0)
rm 0
pm close 7
[DEBUG][espChatFabric/esp-cf-wifi.c:espCfWiFi_callBack:52] disconnect from ssid demo, reason 7
reconnect
state: 2 -> 0 (0)
scandone
no demo found, reconnect after 1s
[DEBUG][espChatFabric/esp-cf-wifi.c:espCfWiFi_callBack:52] disconnect from ssid demo, reason 201
reconnect
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
pm open,type:2 0
[DEBUG][user/user_main.c:clock_loop:380] 1473651600
[DEBUG][user/user_main.c:adcBultin:552] [perUnit: 00.000] ADC0: 004c : volts 00.000
Users browsing this forum: No registered users and 287 guests
