[Solved] Wi-Fi drops after 20-40 seconds
noumes
Postby noumes » Wed Jan 13, 2016 10:56 am
Trying to run a simple application on the ESP8266, specifically the Adafruit HUZZAH ESP8266 breakout.
https://github.com/NoumanSaleem/esp8266-hello-world
The application is compiled using https://github.com/pfalcon/esp-open-sdk, under sdk 1.5, and flashed using esptool.py.
After the app starts, I am able to see my request debug output on my serial monitor, however it stops responding between 20-40 seconds on average. After it stops responding, I can then see the device as inactive under my router.
Here is the command I am running:
while true; do echo -n “fewb” | nc -4u -w1 192.168.1.67 25867; sleep 2; done
To add to the weirdness, if I run a ping in parallel to my command above, everything works fine. Have tested this as working for 5+ minutes.
Any help is greatly appreciated.
noumes
Re: Wi-Fi drops after 20-40 seconds
Postby noumes » Wed Jan 13, 2016 12:29 pm
Have complied using the Espressif provided virtualbox image this time with SDK 1.5.1, and have the same results. Here is the serial output:
connected with iFi, channel 6
dhcp client start...
WiFi Event: 0
ip:192.168.1.67,mask:255.255.255.0,gw:192.168.1.254
IP: 192.168.1.67
Listening for data
Received data!
Received data!
Received data!
Received data!
pm open,type:2 0
Received data!
Received data!
Received data!
Received data!
chg_B1:-40
20 seconds and it stops receiving anything
Postby ESP_Faye » Wed Jan 13, 2016 2:20 pm
What is the "Received data!" ? A TCP packet ?
Does the ESP8266 in station-only mode ?
Please set ESP8266 in station+softAP mode, and try it again.
noumes
Postby noumes » Thu Jan 14, 2016 11:55 am
Faye,
Thanks for your reply.
I have changed:
to
wifi_set_opmode_current(STATIONAP_MODE);
However, I have the same result.
Received data!
is a UDP request callback registered with
espconn_regist_recvcb
In addition, I am also writing the Wifi events
LOCAL void wifiEventHandler(System_Event_t *event) {
  switch (event->event) {
    case EVENT_STAMODE_GOT_IP:
      os_printf("IP: %d.%d.%d.%d\n", IP2STR(&event->event_info.got_ip.ip));
      setupUDP();
    break;
    default:
      os_printf("WiFi Event: %d\n", event->event);
wifi_set_event_handler_cb(wifiEventHandler);
I see
WiFi Event: 7
outputted constantly. My "Received Data" stops after the same duration, around 20 seconds, but the Wifi Event output continues.
The user_main.c can be viewed here: https://github.com/NoumanSaleem/esp8266 ... ser_main.c
Postby ESP_Faye » Wed Jan 20, 2016 4:49 pm
Here is an example of UDP : http://bbs.espressif.com/viewtopic.php?f=31&t=230
Please notice that your "esp_udp udp;" is a local variable, it will be released when "setupUDP()" finish.
noumes
Postby noumes » Thu Jan 28, 2016 12:13 pm
Thank you very much!
