CIPCLOSE Issue
CIPCLOSE Issue
Postby SL!M » Thu Jan 29, 2015 12:05 am
1- set mode as AP and multi connection mode.
2- start a TCP server connection at port 80.
3- connect to the AP, and browse the the ESP ip: 192.168.4.1, you will see the HTTP request.
4- you will get an error when you try to disconnect(AT+CIPCLOSE=0), and the chip will reboot.
Re: CIPCLOSE Issue
Postby ESP_Faye » Thu Jan 29, 2015 11:34 am
Sorry that you have this problem , but we can not replicate it..
Our test steps are as follows:
AT+CWMODE=2
AT+CWSAP="qwerty","123456789"
ERROR
AT+CWSAP="qwerty","123456789",5,3
AT+CIPSERVER=1,80
ERROR
AT+CIPMUX=1
AT+CIPSERVER=1,80
0,CONNECT
+IPD,0,364:GET / HTTP/1.1
Host: 192.168.4.1
Connection: keep-alive
Cache-Control: max-age=0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/39.0.2171.95 Safari/537.36
Accept-Encoding: gzip, deflate, sdch
AT+CIPCLOSE=0
0,CLOSED
Could you offer us more information, like UART output logs ?
Re: CIPCLOSE Issue
Postby SL!M » Thu Jan 29, 2015 4:31 pm
AT+GMR<CR><LF>
AT+GMR<CR>
<CR><LF>
AT version:0.21.0.0<CR><LF>
SDK version:0.9.5<CR><LF>
<CR><LF>
OK<CR><LF>
AT+CIPMUX=1<CR><LF>
AT+CIPMUX=1<CR>
<CR><LF>
<CR><LF>
OK<CR><LF>
AT+CWMODE=2<CR><LF>
AT+CWMODE=2<CR>
<CR><LF>
<CR><LF>
OK<CR><LF>
AT+CIPSERVER=1,80<CR><LF>
<CR><LF>
<CR><LF>
OK<CR><LF>
0,CONNECT<CR><LF>
1,CONNECT<CR><LF>
AT+CIPCLOSE=0<CR><LF>
AT+CIPCLOSE=0<CR>
<CR><LF>
<CR><LF>
+IPD,1,359:GET / HTTP/1.1<CR><LF>
Host: 192.168.4.1<CR><LF>
Connection: keep-alive<CR><LF>
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8<CR><LF>
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/40.0.2214.93 Safari/537.36<CR><LF>
Accept-Encoding: gzip, deflate, sdch<CR><LF>
Accept-Language: en-US,en;q=0.8,zh-CN;q=0.6,zh;q=0.4<CR><LF>
<CR><LF>
0,CONNECT FAIL<CR><LF>
<CR><LF>
OK<CR><LF>
<CR><LF>
ets Jan 8 2013,rst cause:4, boot mode:(3,0)<CR><LF>
<CR><LF>
wdt reset<CR><LF>
load 0x40100000, len 612, room 16 <CR><LF>
tail 4<CR><LF>
chksum 0x12<CR><LF>
load 0x3ffe8000, len 788, room 4 <CR><LF>
tail 0<CR><LF>
chksum 0x50<CR><LF>
load 0x3ffe8314, len 264, room 8 <CR><LF>
tail 0<CR><LF>
chksum 0x4a<CR><LF>
csum 0x4a<CR><LF>
<CR><LF>
2nd boot version : 1.1<CR><LF>
SPI Speed : 40MHz<CR><LF>
SPI Mode : QIO<CR><LF>
SPI Flash Size : 4Mbit<CR><LF>
jump to run user1<CR><LF>
<CR><LF>
rlNÿ<CR><LF>
?ready<CR><LF>
Re: CIPCLOSE Issue
Postby SL!M » Sat Jan 31, 2015 2:09 am
Re: CIPCLOSE Issue
Postby ESP_Faye » Wed Feb 04, 2015 1:54 pm
Thanks for bug reporting !
Please try it with the attachment bin files, and feel free to let us know if you have any question ~
- Attachments
- AT-0.22.b1.0.zip
- (150.07 KiB) Downloaded 1494 times
Re: CIPCLOSE Issue
Postby pa.gregor » Mon Feb 09, 2015 4:01 pm
Espressif_Faye wrote:Hi,
thanks for help, but firmware with this files not work.
After i upgrade firmware module not communicate.
After reset i recived packet with rubbish on serial port.
if i send at command module not replay.
With other firmware module work (ok... with the bugs...
THX
Greg
Re: CIPCLOSE Issue
Postby ESP_Faye » Mon Feb 09, 2015 5:57 pm
The AT bin we released can works fine , baudrate is 115200 , AT commands end with CR LF
Please download as picture below.
- download_tool.png (44.15 KiB) Viewed 27557 times
Re: CIPCLOSE Issue
Postby pa.gregor » Tue Feb 10, 2015 6:50 am
hello,
thx for info.
I make mistake with offset.
After upload firmwa esp work.
Br
Greg
Re: CIPCLOSE Issue
Postby SL!M » Tue Feb 17, 2015 6:31 pm
I tested the attached firmware and the bug is not fixed, still getting the same "0,CONNECT FAIL" and reboot after CIPCLOSE command... I'm sure its flashed correctly "AT version:0.22.b1.0"
anyone else tested the firmware?
Regards,
Ali
Re: CIPCLOSE Issue
Postby jyke » Mon Feb 23, 2015 1:32 am
Thanks for this correction it helped a lot...
i found next issue that happens randomly:
When sending message it looks like second message send fails all the time. So my esp listens tcp port 80 and responds with html message when client connect:
Arduino AT commeand Dubug:
Data available:
0,2 Client connected
AT+CIPSEND=0,64 Sending Firts message
HTTP/1.1 200 OK
Content-Type: text/html
Connection : close
TRUE (TRUE) Message send success
AT+CIPSEND=0,19 [b][i]Sending second message[/i][/b]
<body>
<h1>Hello :TRUE (TRUE) Sending success
AT+CIPSEND=0,70 Sending third message
6</h1><h2> World!</h2><button type="submit" value="LED1">LED1</button>TRUE (TRUE) Sending success
AT+CIPSEND=0,59
<button type="submit" value="LED2">LED2</button>
</body>
TRUE Sending success
AT+CIPCLOSE=0
TRUE
Telnet Client:
HTTP/1.1 200 OK
Connection : close
Location of missing second message
6</h1><h2> World!</h2><button type="submit" value="LED1">LED1</button><button ty
</body>
br,
Jyke
