Hello friends,
I have integrated esp-gdbstub into a project, and am able to do breakpoints, stepping, etc.
However, when I do a backtrace at a breapoint, all the function parameters are labelled with "error reading variable: can't compute CFA for this frame" and cannot be printed. Same effect is seen when trying to examine some (but not all) local variables.
What is the cause of this behavior and how do I work around it?
esp-gdbstub: cannot view local variables
esp03madness
ESP_Sprite
Re: esp-gdbstub: cannot view local variables
Postby ESP_Sprite » Thu Jan 21, 2016 5:26 pm
As far as I understand it, that is a bug in gdb; because of some optimizations gcc does, some variables may be in registers or not available at all, and gdb doesn't know about that. You can try recompiling your code with -Og instead of -Os or whatever -Ox setting you're using now.
rajkumar patel
Postby rajkumar patel » Tue Aug 08, 2017 9:20 pm
i've also tried using gdbstub to debugg my esp8266.
i'm able to stop the execution as soon as i start the session using gdb tool*(esp-idf provided gdb tool i'm using. i.e. xtensa-esp32-elf-gdb).
but then i'm facing an issue which could be seen in attached image.
exact same issue i've found, on esp32 forum, which was getting produced while stepping into debugging session using openOCD - JTAG method.
that thread is here :
https://www.esp32.com/viewtopic.php?f=2 ... 2de8915fff
how could i overcome this issue? please provide your valuable suggestions and shade some light on this.
thanks.
thanks.
