make: Nothing to be done for 'FORCE'.
Postby devehe » Mon Jan 18, 2016 5:37 pm
:~/dev/wsn-2016/esp8266/espressif.com/sdk-nonos/esp_iot_sdk_v1.5.0/app/IoT_Demo$ ./gen_misc.sh
gen_misc.sh version 20150511
enter(0/1/2, default 2):
boot mode: none
enter (0/1/2, default 0):
generate bin: eagle.flash.bin+eagle.irom0text.bin
enter (0/1/2/3, default 2):
spi speed: 40 MHz
enter (0/1/2/3, default 0):
spi mode: QIO
0= 512KB( 256KB+ 256KB)
2=1024KB( 512KB+ 512KB)
3=2048KB( 512KB+ 512KB)
4=4096KB( 512KB+ 512KB)
5=2048KB(1024KB+1024KB)
6=4096KB(1024KB+1024KB)
spi size: 512KB
spi ota map: 256KB + 256KB
start...
PaulTsai111
Re: make: Nothing to be done for 'FORCE'.
Postby PaulTsai111 » Thu May 05, 2016 8:54 am
I tried to use the Non-RTOS Systems to compile the examples that espressif provided.
Here is the contents that I do for compiling!!
esp8266@esp8266-VirtualBox:~/Share/ESP8266_NONOS_SDK/examples/smart_config$ ./gen_misc.sh
0
boot mode: old
0
ignore boot
0
spi speed: 20 MHz
0
spi mode: QIO
0
spi size: 512KB
start...
make: Nothing to be done for `FORCE'.
esp8266@esp8266-VirtualBox:~/Share/ESP8266_NONOS_SDK/examples/smart_config$ pwd
/home/esp8266/Share/ESP8266_NONOS_SDK/examples/smart_config
Here is the message that I have met that can not be solved.
I do know how to correct this problems? please do help!! thanks
PaulTsai111
Postby PaulTsai111 » Thu May 05, 2016 7:01 pm
according to my folders directory, I do not find the folders directory as you described
above. Is there anything wrong ? or I just need to do something ??
esp8266@esp8266-VirtualBox:~/Share/ESP8266_NONOS_SDK$ cd examples
esp8266@esp8266-VirtualBox:~/Share/ESP8266_NONOS_SDK/examples$ ls
at IoT_Demo peripheral_test smart_config
at_espconn lwip_open_src_template_proj readme.txt wps
esp8266@esp8266-VirtualBox:~/Share/ESP8266_NONOS_SDK/examples$ cd IoT_Demo/
esp8266@esp8266-VirtualBox:~/Share/ESP8266_NONOS_SDK/examples/IoT_Demo$ pwd
/home/esp8266/Share/ESP8266_NONOS_SDK/examples/IoT_Demo
Postby ESP_Faye » Fri May 06, 2016 2:14 pm
In your case, you need to move the folder "IoT_Demo" to directory /Share/ESP8266_NONOS_SDK/IoT_Demo.
PaulTsai111
Postby PaulTsai111 » Fri May 06, 2016 3:50 pm
after changing the working directories of the IoT_Demo.
and recompile the IoT_Demo project, it seems works but I did not
know the following messages. "No boot needed, what does that mean?"
Can you clearly describe what does it mean??
Thanks you.
No boot needed.
Generate eagle.flash.bin and eagle.irom0text.bin successully in folder bin.
eagle.flash.bin-------->0x00000
eagle.irom0text.bin---->0x40000
esp8266@esp8266-VirtualBox:~/Share/ESP8266_NONOS_SDK/IoT_Demo$ ./gen_misc.sh
0
boot mode: old
0
ignore boot
0
spi speed: 20 MHz
2
spi mode: DIO
2
spi size: 1024KB
spi ota map: 512KB + 512KB
start...
make[1]: Entering directory `/mnt/Share/ESP8266_NONOS_SDK/IoT_Demo/user'
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_webserver.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_sensor.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_plug.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_main.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_light.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_light_adj.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_json.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_esp_platform_timer.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_esp_platform.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_devicefind.c
make[1]: Leaving directory `/mnt/Share/ESP8266_NONOS_SDK/IoT_Demo/user'
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_devicefind.o -c user_devicefind.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_esp_platform.o -c user_esp_platform.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_esp_platform_timer.o -c user_esp_platform_timer.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_json.o -c user_json.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_light_adj.o -c user_light_adj.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_light.o -c user_light.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_main.o -c user_main.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_plug.o -c user_plug.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_sensor.o -c user_sensor.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_webserver.o -c user_webserver.c
xtensa-lx106-elf-ar ru .output/eagle/debug/lib/libuser.a .output/eagle/debug/obj/user_devicefind.o .output/eagle/debug/obj/user_esp_platform.o .output/eagle/debug/obj/user_esp_platform_timer.o .output/eagle/debug/obj/user_json.o .output/eagle/debug/obj/user_light_adj.o .output/eagle/debug/obj/user_light.o .output/eagle/debug/obj/user_main.o .output/eagle/debug/obj/user_plug.o .output/eagle/debug/obj/user_sensor.o .output/eagle/debug/obj/user_webserver.o
xtensa-lx106-elf-ar: creating .output/eagle/debug/lib/libuser.a
make[1]: Entering directory `/mnt/Share/ESP8266_NONOS_SDK/IoT_Demo/driver'
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include key.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include i2c_master.c
make[1]: Leaving directory `/mnt/Share/ESP8266_NONOS_SDK/IoT_Demo/driver'
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/i2c_master.o -c i2c_master.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/key.o -c key.c
xtensa-lx106-elf-ar ru .output/eagle/debug/lib/libdriver.a .output/eagle/debug/obj/i2c_master.o .output/eagle/debug/obj/key.o
xtensa-lx106-elf-ar: creating .output/eagle/debug/lib/libdriver.a
xtensa-lx106-elf-gcc -L../lib -nostdlib -T../ld/eagle.app.v6.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lcrypto -lmain -ljson -lupgrade -lssl -lpwm -lsmartconfig user/.output/eagle/debug/lib/libuser.a driver/.output/eagle/debug/lib/libdriver.a -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out
No boot needed.
Postby ESP_Faye » Mon May 09, 2016 10:36 am
There are 2 types of the bin files.
1. Non-boot type which can not use FOTA (upgrade firmware through WiFi) function.
eagle.flash.bin + eagle.irom0text.bin
2. With-boot type which can add FOTA function.
boot.bin + use1.bin (or user2.bin)
ESP8266 Getting Started Guide.
Postby auxking » Sun Nov 06, 2016 4:31 am
ESP_Faye wrote:Hi,
Hi, I'm having this issue as well and changing the directory of the IoT_Demo folder has done nothing; I still get the same FORCE error. I've been able to compile and flash other bin files, but this IoT_Demo doesn't work! What else can I try? Should I modify the Makefile?
Thanks,
Jim
