SmartConfig Issue
esp8266ac
SmartConfig Issue
Postby esp8266ac » Tue Jan 19, 2016 6:10 pm
Hi All:
One question about smartconfig:
Scenario:
1. ESP8266 got right SSID/Passwd once & worked OK.
2. After somedays, ESP8266 could NOT connect router any longer,
Root causes could be: a. SSID/Passwd changed, b. router faults temporarily, c. router removed.
ESP8266 can NOT switch from work mode to smartconfig mode without any end user's determination & operation (such as reset button to clear SSID/Passwd)
3. End user just want to reconfigure SSID/Passwd via smartconfig feature in App
To resolve the above issues, new requirements:
Smartconfig always standby either ESP8266 are NOT configured SSID/Passwd or configured SSID/Passwd (connected or NOT connected).
Could RTOS SDK support the above smartconfig mode? any sample code if YES?
Any work around approaches if NOT?
Many thanks!
B.R.
Macrogram
Re: SmartConfig Issue
Postby ESP_Faye » Wed Jan 20, 2016 3:22 pm
You can register WiFi event handler by calling wifi_set_event_handler_cb. When WiFi status changed, there will be corresponding WiFi event.
For example, if you got "EVENT_STAMODE_DISCONNECTED", you can try to connect to router by SmartConfig again.
