最新RTOS版SDK overlap问题
zhangjinliang
Postby zhangjinliang » Wed Jan 20, 2016 4:10 pm
你好:
我把代码从旧版本的SDK切换到最新的RTOS版本的SDK上。初始化HSPI的overlap后(如下),
SET_PERI_REG_MASK(0x3ff00028, BIT(7));
//set higher priority for spi than hspi
SET_PERI_REG_MASK(SPI_EXT3(SPI), 0x1);
SET_PERI_REG_MASK(SPI_EXT3(HSPI), 0x3);
SET_PERI_REG_MASK(SPI_USER(HSPI), BIT(5));
做了以上初始化后,用spi_flash_read这个接口去访问SPI外挂的FLASH,无法返回,卡住一段时间后异常复位,异常信息时乱码。
如果没有以上初始化overlap的过程,访问时OK的。同时旧版本也是OK的。
麻烦帮忙定位一下问题所在?
麻烦帮忙定位一下问题所在?
zhangjinliang
Re: 最新RTOS版SDK overlap问题
Postby zhangjinliang » Sat Jan 23, 2016 8:28 pm
请乐鑫的FAE帮忙验证一下, 最新的RTOS sdk是否有上述问题!!多谢
tobewinner
Postby tobewinner » Thu Mar 31, 2016 6:03 pm
我使用的1.3.1 2016-11-16的RTOS SDK有同样的问题,是否RTOS SDK不支持overlap?
Postby ESP_Faye » Fri Apr 01, 2016 10:40 am
您好,
麻烦基于 ESP8266_RTOS_SDK_V1.4.0 更新附件 lib。
如果您的问题仍未解决,请再告知。
感谢您对 ESP8266 的关注!
如果您的问题仍未解决,请再告知。
感谢您对 ESP8266 的关注!
- Attachments
- libmain_for_ESP8266_RTOS_SDK_V1.4.0.zip
- (54.4 KiB) Downloaded 777 times
Postby Han » Mon Oct 31, 2016 5:56 am
I may be experiencing this very same problem with the NONOS SDK V1.5.3 (PlatformIO/Arduino).
Whenever the statement is executed, subsequent calls to SPIFFS (e.g. file.open) fail and cause an exception.
Was the solution to this problem ever added to the NONOS SDKs?
What exactly does the above statement do? I understand that the SPI port priorities are set, but the exact definition of the the lower two bits of the SPI_EXT3 register is unclear to me.
Han
SET_PERI_REG_MASK(SPI_EXT3(SPI), 0x1)Was the solution to this problem ever added to the NONOS SDKs?
Han
