WDT reset on pwm_init
snapdan
Postby snapdan » Sun Jan 24, 2016 9:36 am
I'm able to get pwm working with the following code:
#include "ets_sys.h"
#include "osapi.h"
#include "user_interface.h"
void show_mac (void) {
    unsigned char mac[6];
    // wifi_get_macaddr ( STATION_IF, mac );
    // os_printf ( "MAC: %02x:%02x:%02x:%02x:%02x:%02x\n",
    // mac[0], mac[1], mac[2], mac[3], mac[4], mac[5] );
void user_init() {
    gpio_init();
    uint32_t io_info[1][3] = {
                          {PERIPHS_IO_MUX_MTCK_U,FUNC_GPIO13,13},
    uint32_t duty[1] = {500};
    pwm_init(1000, duty,1,io_info);
    pwm_start();
    // show_mac ();
However, if I un-comment just line 7 so it's like so:
#include "osapi.h"
void user_init() {
    gpio_init();
    pwm_start();
    // show_mac ();
It crashes:
ets Jan 8 2013,rst cause:4, boot mode:(1,0)
wdt reset
Which is especially strange since I'm still not even calling the show_mac() function!
I'm using the pfalcon/open-sdk and toolchain, which uses the v1.4.0 sdk. Here's the makefile I'm using:
# Makefile for older versions (<1.0) of Espressif "AT" firmware
CC = xtensa-lx106-elf-gcc
CFLAGS = -I. -mlongcalls
LDLIBS = -nostdlib -Wl,--start-group -lmain -lupgrade -lnet80211 -lwpa -llwip -lpp -lphy -Wl,--end-group -lcirom -lgcc -lpwm
LDFLAGS = -Teagle.app.v6.ld
malarm-0x00000.bin: malarm
   esptool.py elf2image $^
malarm: malarm.o
   $(CC) $(LDFLAGS) $^ -o $@ $(LDLIBS)
malarm.o: malarm.c
flash: malarm-0x00000.bin
   esptool.py write_flash 0 malarm-0x00000.bin 0x40000 malarm-0x40000.bin
connect:
   picocom -b 115200 --omap crcrlf /dev/ttyUSB0
Any thoughts or ideas? Thanks.
Re: WDT reset on pwm_init
Postby ESP_Faye » Mon Jan 25, 2016 5:00 pm
If you want to download firmware into Flash, it is : MTDO:0,GPIO0:0,GPIO2:1.
If you want to run the firmware, it is : MTDO:0,GPIO0:1,GPIO2:1.
It seems your GPIO0 is still in low-level, so the ESP8266 could not run the firmware.
snapdan
Postby snapdan » Tue Jan 26, 2016 9:38 am
Espressif_Faye wrote:Hi,
Ah, thank you but that's not the problem. Sorry - I should have been clearer with the debug output. With this code
#include "osapi.h"
void user_init() {
    gpio_init();
    pwm_start();
    // show_mac ();
the pwm works (I have it connected to a piezo and it's making a tone) and I get the expected output
r��`rlmode : sta(18:fe:34:9f:da:75) + softAP(1a:fe:34:9f:da:75)
add if0
add if1
bcn 100
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with MuseumWorst, channel 5
dhcp client start...
ip:192.168.1.81,mask:255.255.255.0,gw:192.168.1.254
When I un-comment line 7 - which is never even used:
#include "osapi.h"
void user_init() {
    gpio_init();
    pwm_start();
    // show_mac ();
I get constant wdt resets and it never seems to make it through pwm_init (the piezo is silent) :
b��`rlmode : sta(18:fe:34:9f:da:75) + softAP(1a:fe:34:9f:da:75)
add if0
add if1
ets Jan 8 2013,rst cause:4, boot mode:(3,0)
wdt reset
load 0x40100000, len 27360, room 16
tail 0
chksum 0x5d
load 0x3ffe8000, len 904, room 8
tail 0
chksum 0x9d
load 0x3ffe8388, len 244, room 8
tail 12
chksum 0xbf
csum 0xbf
add if0
add if1
wdt reset
tail 0
chksum 0x5d
tail 0
chksum 0x9d
tail 12
chksum 0xbf
csum 0xbf
add if0
add if1
Even just trying to add any more debug messages with os_printf causes the resets as well.
Postby ESP_Faye » Thu Jan 28, 2016 12:10 pm
I tested your code, it works fine, no WDT reset.
Did you download a wrong bin file ? It seems that your log is not corresponding to your test code.
In your log, the ESP8266 connects to a router, but there is no this part in your test code.
snapdan
Postby snapdan » Sun Jan 31, 2016 3:23 am
Thanks for checking. It was connecting to a router because it was stored in flash. I cleared that with system_restore() and changed the code but it still resets when it gets to the pwm_init.
This code:
#include "osapi.h"
void user_init() {
    // wifi_set_opmode_current(STATION_MODE);
    wifi_set_opmode_current(SOFTAP_MODE);
    gpio_init();
    pwm_start();
Gets this output:
�lrl�mode : softAP(1a:fe:34:9f:da:75)
add if1
wdt reset
load 0x40100000, len 27336, room 16
tail 8
chksum 0x9f
load 0x3ffe8000, len 904, room 0
tail 8
chksum 0x5f
load 0x3ffe8388, len 244, room 0
tail 4
chksum 0x7d
csum 0x7d
add if1
wdt reset
tail 8
chksum 0x9f
tail 8
chksum 0x5f
tail 4
chksum 0x7d
csum 0x7d
add if1
This code:
#include "osapi.h"
void user_init() {
    // wifi_set_opmode_current(SOFTAP_MODE);
    gpio_init();
    pwm_start();
Gets this output:
�l�lrl�mode : sta(18:fe:34:9f:da:75)
add if0
wdt reset
tail 8
chksum 0x9c
tail 8
chksum 0x5c
tail 4
chksum 0x7e
csum 0x7e
add if0
wdt reset
tail 8
chksum 0x9c
tail 8
chksum 0x5c
tail 4
chksum 0x7e
csum 0x7e
add if0
This code works and I get the expected tone from the piezo:
#include "osapi.h"
void user_init() {
    gpio_init();
    pwm_start();
Output:
r��`rlmode : softAP(1a:fe:34:9f:da:75)
add if1
bcn 100
Postby ESP_Faye » Tue Feb 02, 2016 11:51 am
Here is our entire test project, sorry that we could not duplicate your problem.
user_main.c is the source code you provided.
\esp_iot_sdk_test\bin are our bin files after compiling the test code, please download and have a try.
esp_iot_sdk_test.zip
(2.87 MiB) Downloaded 645 times
snapdan
Postby snapdan » Mon Feb 15, 2016 2:12 am
Thank you, I finally got around to testing this and it works as expected. Does this mean something is wrong with my toolchain?
anszom
Postby anszom » Sat Apr 23, 2016 4:30 pm
This is a SDK bug. See here for details: http://www.esp8266.com/viewtopic.php?f= ... =48#p46002
Postby ESP_Faye » Tue May 31, 2016 9:34 am
Sorry that we can not reproduce your problem.
Here is our test code, please have a try and feel free to let us know, if your problem is still unsolved.
app_dbg_wdt_For_ESP8266_NONOS_SDK_V1.4.0_201605.zip
(72.15 KiB) Downloaded 581 times
