return code ???
criki
return code ???
Postby criki » Sun Jan 24, 2016 6:16 pm
Hello everybody,
Good product, congratulations, I just have some minor problems
1) CIPSTATUS return 5 which is not in the 0.40 documentation (end at 4) what '5' means ???
2) ESP8266 is in AP mode, 3 PCs are wifi connected to ESP8266 with a small UDP application (send/receive)
I see the PCs via AT+CWLIF (192.168.4.2 , .3 and .4) this is correct
I do AT+CIPSTART="UDP","192.168.4.2",6767,6768,0 this is correct too
Now I receive +IPD ... from all the stations means I cannot know from where (IP adress) a UDP datagram arrives and why I need to do a CIPSTART if it doesn't filter incoming messages ???
Kind regards
c.legal@free.fr
Re: return code ???
Postby ESP_Faye » Mon Jan 25, 2016 5:25 pm
1) Sorry that we missed it, status 5 means WiFi connection fail, we will add it in the next version of documentation.
2) Please use the latest AT firmware v1.5.0. Command "AT+CIPDINFO=1" can enable showing the remote information in "+IPD". Then you can set a filter yourself.
