#include "esp_common.h"
#include "espconn.h"
#include "user_config.h"
void recvCB(void *arg, char *pData, unsigned short len);
void eventCB(System_Event_t *event);
void setupUDP();
void recvCB(void *arg, char *pData, unsigned short len) {
struct espconn *pEspConn = (struct espconn *)arg;
printf("Received data!! - length = %d\n", len);
printf(pData);
} // End of recvCB
void setupUDP() {
static struct espconn conn1;
static esp_udp udp1;
udp1.local_port = 25867;
conn1.type = ESPCONN_UDP;
conn1.state = ESPCONN_NONE;
conn1.proto.udp = &udp1;
espconn_create(&conn1);
espconn_regist_recvcb(&conn1, recvCB);
printf("Listening for data\n");
} // End of setupUDP
void eventCB(System_Event_t *event) {
switch (event->event_id) {
case EVENT_STAMODE_GOT_IP:
printf("IP: %d.%d.%d.%d\n", IP2STR(&event->event_info.got_ip.ip));
setupUDP();
break; }
} // End of eventCB
void tskconnect(void *pvParameters) {
//Wait a few secs for the stack to settle down
vTaskDelay(3000/portTICK_RATE_MS);
wifi_set_event_handler_cb(eventCB);
//Go to station mode
wifi_station_disconnect();
if (wifi_get_opmode() != STATION_MODE) {
//Connect to the defined access point.
struct station_config *config=malloc(sizeof(struct station_config));
memset(config, 0x00, sizeof(struct station_config));
sprintf(config->ssid, AP_NAME);
sprintf(config->password, AP_PASS);
wifi_station_set_config(config);
wifi_station_connect();
free(config);
//We're done. Delete this task.
vTaskDelete(NULL);
void user_init(void)
xTaskCreate(tskconnect, "tskconnect", 200, NULL, 3, NULL);
Yields
root@esp8266-VirtualBox:/home/esp8266/Share/ESP8266_RTOS_SDK/examples/project_template# ./gen_misc.sh
gen_misc.sh version 20150911
SDK_PATH:
BIN_PATH:
/home/esp8266/Share/ESP8266_RTOS_SDK/bin
Please check SDK_PATH & BIN_PATH, enter (Y/y) to continue:
y
STEP 1: use boot_v1.2+ by default
boot mode: new
enter (0/1/2, default 0):
ignore boot
generate bin: eagle.flash.bin+eagle.irom0text.bin
enter (0/1/2/3, default 2):
spi speed: 40 MHz
enter (0/1/2/3, default 0):
spi mode: QIO
0= 512KB( 256KB+ 256KB)
2=1024KB( 512KB+ 512KB)
3=2048KB( 512KB+ 512KB)
4=4096KB( 512KB+ 512KB)
5=2048KB(1024KB+1024KB)
6=4096KB(1024KB+1024KB)
spi size: 512KB
spi ota map: 256KB + 256KB
start...
make -C user clean; make -C driver clean;
make[1]: Entering directory `/mnt/Share/ESP8266_RTOS_SDK/examples/project_template/user'
rm -f -r .output/eagle/debug
make[1]: Leaving directory `/mnt/Share/ESP8266_RTOS_SDK/examples/project_template/user'
make[1]: Entering directory `/mnt/Share/ESP8266_RTOS_SDK/examples/project_template/driver'
make[1]: Leaving directory `/mnt/Share/ESP8266_RTOS_SDK/examples/project_template/driver'
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../include -I /home/esp8266/Share/ESP8266_RTOS_SDK/include -I /home/esp8266/Share/ESP8266_RTOS_SDK/extra_include -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/espressif -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip/ipv4 -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip/ipv6 -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/nopoll -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/spiffs -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/ssl user_main.c
make[1]: Warning: File `.output/eagle/debug/obj/user_main.d' has modification time 3.4 s in the future
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../include -I /home/esp8266/Share/ESP8266_RTOS_SDK/include -I /home/esp8266/Share/ESP8266_RTOS_SDK/extra_include -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/espressif -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip/ipv4 -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip/ipv6 -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/nopoll -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/spiffs -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/ssl -o .output/eagle/debug/obj/user_main.o -c user_main.c
xtensa-lx106-elf-ar ru .output/eagle/debug/lib/libuser.a .output/eagle/debug/obj/user_main.o
xtensa-lx106-elf-ar: creating .output/eagle/debug/lib/libuser.a
make[1]: warning: Clock skew detected. Your build may be incomplete.
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ../include -I /home/esp8266/Share/ESP8266_RTOS_SDK/include -I /home/esp8266/Share/ESP8266_RTOS_SDK/extra_include -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/espressif -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip/ipv4 -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip/ipv6 -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/nopoll -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/spiffs -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/ssl i2s_freertos.c
make[1]: Warning: File `.output/eagle/debug/obj/i2s_freertos.d' has modification time 3.6 s in the future
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ../include -I /home/esp8266/Share/ESP8266_RTOS_SDK/include -I /home/esp8266/Share/ESP8266_RTOS_SDK/extra_include -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/espressif -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip/ipv4 -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/lwip/ipv6 -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/nopoll -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/spiffs -I /home/esp8266/Share/ESP8266_RTOS_SDK/include/ssl -o .output/eagle/debug/obj/i2s_freertos.o -c i2s_freertos.c
xtensa-lx106-elf-ar ru .output/eagle/debug/lib/libdriver.a .output/eagle/debug/obj/i2s_freertos.o
xtensa-lx106-elf-ar: creating .output/eagle/debug/lib/libdriver.a
make: Warning: File `user/.output/eagle/debug/lib/libuser.a' has modification time 3.1 s in the future
xtensa-lx106-elf-gcc -L/home/esp8266/Share/ESP8266_RTOS_SDK/lib -Wl,--gc-sections -nostdlib -T/home/esp8266/Share/ESP8266_RTOS_SDK/ld/eagle.app.v6.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lminic -lgcc -lhal -lphy -lpp -lnet80211 -lwpa -lcrypto -lmain -lfreertos -llwip user/.output/eagle/debug/lib/libuser.a driver/.output/eagle/debug/lib/libdriver.a -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out
user/.output/eagle/debug/lib/libuser.a(user_main.o): In function `tskconnect':
/mnt/Share/ESP8266_RTOS_SDK/examples/project_template/user/user_main.c:79: undefined reference to `espconn_create'
/mnt/Share/ESP8266_RTOS_SDK/examples/project_template/user/user_main.c:79: undefined reference to `espconn_regist_recvcb'
user/.output/eagle/debug/lib/libuser.a(user_main.o): In function `setupUDP':
/mnt/Share/ESP8266_RTOS_SDK/examples/project_template/user/user_main.c:49: undefined reference to `espconn_create'
/mnt/Share/ESP8266_RTOS_SDK/examples/project_template/user/user_main.c:50: undefined reference to `espconn_regist_recvcb'
