[AT Release] ESP8266_AT_V0.60 based on ESP8266_NONOS_SDK_V1.5.2
Postby ESP_Faye » Fri Jan 29, 2016 9:00 pm
ESP8266_AT_v0.60 Release based on ESP8266_NONOS_SDK_V1.5.2
  1. Use Espressif official Flash Download Tool to download AT firmware bin files into Flash according to the "readme.txt" which is in the attachment.
  2. Since this ESP8266_AT_v0.51, AT firmware is too large to fit in 4Mbit (512KB) Flash. Please use 8Mbit (1MB) or larger Flash.
  3. Firmware upgrade over-the-air process is changed a bit. We will upgrade the latest AT firmware to Espressif Cloud server only after it has been tested and the overall performance is guaranteed. Users may not be able to use AT+CIUPDATE in ESP8266_NONOS_SDK_V1.5.0 and other more advanced versions.
Important Links
Here are the links for this AT release (version ESP82566_AT_v0.60 based on ESP8266_NONOS_SDK_V1.5.2):
  1. ESP8266_NONOS_SDK_V1.5.2
  2. Espressif official Flash Download Tool
  3. AT Commands Documentation
  4. Bug Bounty Program
Release Notes
  1. Added command AT+CWLAPOPT, which is used to config the attribute of the returned value of the command AT+CWLAP.
  2. Added command AT+WPS, WPS supported.
  3. Added command AT+MDNS, MDSN supported.
  4. Added command AT+CWSTARTDISCOVER/AT+CWSTOPDISCOVER. AirKiss intranet detecting function is supported.
  5. Optimized command AT+CIPSTART. The device can function as SSL client, and one SSL connection can be created at most.
  6. Optimized AT+UART command.
Have fun!
ESP8266_AT_v0.60 发布,基于 ESP8266_NONOS_SDK_V1.5.2
  1. 请使用 Espressif 官方 Flash Download Tool,参考附件压缩包中的 “readme.txt” 烧录 AT 固件到 Flash 中。
  2. 如需支持固件升级功能 (AT+CIUPDATE),Flash 容量要求 1MBytes 或以上,烧录使用 boot mode。
  3. 我司优化了 AT 固件的升级流程,AT 固件发布后,会等一段时间,待客户反馈稳定后,才上传到 Espressif Cloud 以供下载更新。因此,如果使用 ESP8266_NONOS_SDK_V1.5.0 及之后版本的 AT 固件暂时无法从 Espressif Cloud 升级。
相关下载
    以下是最新SDK的相关下载链接 (版本 ESP8266_AT_v0.60 基于 ESP8266_NONOS_SDK_V1.5.2):
  1. ESP8266_NONOS_SDK_V1.5.2。
  2. Espressif 官方 Flash Download Tool。
  3. AT 文档下载链接。
  4. 您可以继续参与 Bug Bounty 计划。
发布说明
  1. 新增 AT+CWLAPOPT 指令,用于设置 AT+CWLAP 指令的返回结果属性。
  2. 新增 AT+WPS 指令,支持 WPS 功能。
  3. 新增 AT+MDNS 指令,支持 MDNS 功能。
  4. 新增 AT+CWSTARTDISCOVER/AT+CWSTOPDISCOVER 指令,支持微信的内网发现功能。
  5. 优化 AT+CIPSTART 命令,支持作为 SSL client,最多可创建 1 个 SSL 连接。
  6. 修正设置波特率后最后一个字符错误的问题。
感谢您对 ESP8266 的关注!
AT_V0.60_on_ESP8266_NONOS_SDK_V1.5.2_20160203.zip
20160203 updated for AT+CWLAP issue
(1.36 MiB) Downloaded 7495 times
