Hello
I have been unable to quit a UART-WiFi passthrough transmission by inputting "+++" as per the documentation. Instead +++ is transferred through the TCP connection and I receive an error from the server. The only way to get the ESP8266 out of this mode is to reset.
AT v0.52 and v0.60
AT+CIPMODE=1
AT+CIPSTART
AT+CIPSEND
I believe this is a bug.
[Solved] UART-WiFi passthrough +++ does not quit transmission
Re: UART-WiFi passthrough +++ does not quit transmission
Postby ESP_Faye » Thu Feb 04, 2016 3:57 pm
It is not a bug, it depends on your UART tool.
The "+++" has to be send through UART as a whole packet, if you just input it on keyboard, it may take a too long time as 3 "+" characters separated from each other.
You need a UART tool that will send the "+++" as a whole packet, and no more other invisible characters (for example, it should not have \r\n, a new line).
Postby BlitzSSS » Thu Feb 04, 2016 4:38 pm
Espressif_Faye wrote:You need a UART tool that will send the "+++" as a whole packet, and no more other invisible characters (for example, it should not have \r\n, a new line).
Thank you Faye, invisible characters \r\n was the problem.
Would be worth adding a note about the invisible characters to the AT Instructions Set and AT Example Documentation.
