How do I prevent a connection to re-connect after connectin lost?
NEIL
Postby NEIL » Sat Feb 06, 2016 12:13 am
I am using the 8266 in transparent mode, and connected to my server application. All works well, but if for some reason the connection is lost, the connection is re-established automatically (I can see multiple attempts in Wireshark from the device). After the connection is re-established, there is no way of my application (from the 8266 side) of known this has happened. The way I have written the server application , this cant be allowed as there has to be a login sequence. I wasnt sure if the timeout parameter in the at+cipstart is used for this, but I get an error if I add it. Below is what I tried , I added the last two parameters but got error (I replaced my ip to xxx.xxx.xxx.xxx for here only)
AT+CIPSTART="TCP","xxx.xxx.xxx.xxx",1963,1964,0
at+gmr returns :
AT version:0.60.0.0(Jan 29 2016 15:10:17)
SDK version:1.5.2(80914727)
compile time:Jan 29 2016 19:07:08
Neil
Re: How do I prevent a connection to re-connect after connectin lost?
Postby ESP_Faye » Fri Apr 01, 2016 10:19 am
Sorry for the inconvenience.
In UART-TCP passthrough mode, if the TCP connection broke, the ESP8266 will re-connect it automatically. If the MCU continually send data through UART, the data will be lost.
