RTOS Software timer
hreintke
RTOS Software timer
Postby hreintke » Tue Feb 09, 2016 3:49 am
I am busy converting the sming framework from NONOS SDK to RTOS SDK.
In that I noticed a very different behavior of the Software Timer in both SDK's.
For clarity, I am using the Timer from SDK os_timer_arm, not the RTOS timer.
My test consists of 4 timers running simultaneous. Resolution 1ms, 2ms, 3ms, 4ms.
Within the timer, a gpio pin is toggled -> blinking
This is the result in NONOS :
This is the result in RTOS :
Can you explain the difference.?
What is the the way to get similar behavior using RTOS SDK ?
cvgaviao
Re: RTOS Software timer
Postby cvgaviao » Tue Jan 10, 2017 7:10 pm
@hreintke,
have you discovered the reason for such behavior ?
is still Sming RTOS on active development ?
thanks
Users browsing this forum: No registered users and 310 guests
