SOFTAP - Some devices can not connect JOIN-LEAVE
Klaus W.
Postby Klaus W. » Sat Feb 13, 2016 5:28 am
i'm using ESP8266 with SOFTAP-Mode.
Connecting and using web-server with my android mobile phones works without problems. Also kolleagues do not reported any problem.
I want to connect with my notebook too and it's not possibel, or in other word: for very short times: It joins and leaves permanently the AP.
Please help me or give any advice.
I'm using SDK 1.3 and following LOG i recorded:
add 1
aid 1
station: 5c:c5:d4:de:4c:ac join, AID = 1
station: 5c:c5:d4:de:4c:ac leave, AID = 1
rm 1
. 60
. 61
add 1
aid 1
rm 1
I tried SDK 1.1 and SDK 1.2 too without any success.
Here the used initialization sequence:
void dhcps_lease(void)
struct dhcps_lease dhcp_lease;
IP4_ADDR(&dhcp_lease.start_ip, 10, 10, 10, 20);
IP4_ADDR(&dhcp_lease.end_ip, 10, 10, 10, 100);
wifi_softap_set_dhcps_lease(&dhcp_lease);
//Main routine. Initialize stdout, the I/O and the webserver and we're done.
void user_init(void)
ioObj=&ioObj_static;
struct softap_config apConfig;
struct ip_info ipinfo;
char ssid[33];
char password[33];
char macaddress[17];
char info[150];
int i;
struct SettingsData *settings;
system_timer_reinit();
ets_wdt_disable();
stdoutInit();
for(i=0;i<1000;i++) os_delay_us(1000);
ets_wdt_enable();
os_printf("Starting\r\n");
settings=getSettingsDataPtr();
if (1==1 || readSettings()==false)
os_printf("Read Failed\r\n");
os_sprintf(settings->password,"%s","esptemplate");
os_sprintf(settings->ssid,"%s","esptemplate");
os_sprintf(settings->configstring,"");
for(i=0; i<40; i++) settings->params[i]=0L;
writeSettings();
if( wifi_get_phy_mode() != PHY_MODE_11G )
os_printf("*** Setting PHY_MODE ...\r\n");
wifi_set_phy_mode( PHY_MODE_11B );
if(wifi_get_opmode() != SOFTAP_MODE)
wifi_set_opmode_current(SOFTAP_MODE);
wifi_softap_dhcps_stop();
IP4_ADDR(&ipinfo.ip, 10, 10, 10, 1);
IP4_ADDR(&ipinfo.gw, 10, 10, 10, 1);
IP4_ADDR(&ipinfo.netmask, 255, 255, 255, 0);
wifi_set_ip_info(SOFTAP_IF, &ipinfo);
wifi_softap_get_config(&apConfig);
os_memset(apConfig.ssid, 0, sizeof(apConfig.ssid));
os_sprintf(ssid, "%s", settings->ssid);
os_memcpy(apConfig.ssid, ssid, os_strlen(ssid));
// if (wifi_get_opmode() == SOFTAP_MODE)
if (1==0)
// SSID
os_memset(apConfig.password, 0, sizeof(apConfig.password));
os_sprintf(password, "%s", settings->password);
os_memcpy(apConfig.password, password, os_strlen(password));
apConfig.authmode = AUTH_WPA_WPA2_PSK;
else
// without password
os_sprintf(ssid, "%s", "esptemplate2");
apConfig.authmode = AUTH_OPEN;
apConfig.channel = 1;
apConfig.max_connection = 2;
apConfig.ssid_hidden = 0;
apConfig.ssid_len = 0;
apConfig.beacon_interval = 100;
wifi_softap_set_config_current(&apConfig);
dhcps_lease();
wifi_softap_dhcps_start();
system_os_task(at_procTask, at_procTaskPrio, at_procTaskQueue, at_procTaskQueueLen);
system_os_post(at_procTaskPrio, 0, 0 );
processIO(ioObj,ioAction_init);
processIO(ioObj,ioAction_setOutputs);
// os_timer_disarm(ETSTimer *ptimer)
os_timer_disarm(&working_timer);
// os_timer_setfn(ETSTimer *ptimer, ETSTimerFunc *pfunction, void *parg)
os_timer_setfn(&working_timer, (os_timer_func_t *)working_cb, (void *)0);
// void os_timer_arm(ETSTimer *ptimer,uint32_t milliseconds, bool repeat_flag)
os_timer_arm(&working_timer, 100, 1);
//httpdInit(builtInUrls, 80);
os_printf("\nReady\n");
Re: SOFTAP - Some devices can not connect JOIN-LEAVE
Postby ESP_Faye » Mon Mar 07, 2016 3:15 pm
1. Could it connect if just using a simple softAP test code http://bbs.espressif.com/viewtopic.php?f=31&t=227 ?
2. Can you capture the WiFi packets and provide it for debugging ?
