i2s NONOS demo fails missing definitions
noumes
Postby noumes » Sat Feb 13, 2016 9:15 am
The i2s demo fails to compile against NONOS 1.5.x (viewtopic.php?f=31&t=1343)
I see this file contains the required definitions for RTOS sdk
https://github.com/espressif/ESP8266_RT ... register.h
In file included from ../../include/ets_sys.h:12:0,
from ../include/driver/spi.h:5,
from i2s.c:1:
i2s.c: In function 'i2s_init':
i2s.c:150:41: error: 'FUNC_I2SI_DATA' undeclared (first use in this function)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, FUNC_I2SI_DATA);
../../include/eagle_soc.h:50:98: note: in definition of macro 'WRITE_PERI_REG'
#define WRITE_PERI_REG(addr, val) (*((volatile uint32_t *)ETS_UNCACHED_ADDR(addr))) = (uint32_t)(val)
i2s.c:150:2: note: in expansion of macro 'PIN_FUNC_SELECT'
i2s.c:150:41: note: each undeclared identifier is reported only once for each function it appears in
i2s.c:151:41: error: 'FUNC_I2SI_BCK' undeclared (first use in this function)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, FUNC_I2SI_BCK);
i2s.c:151:2: note: in expansion of macro 'PIN_FUNC_SELECT'
i2s.c:152:41: error: 'FUNC_I2SI_WS' undeclared (first use in this function)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTMS_U, FUNC_I2SI_WS);
i2s.c:152:2: note: in expansion of macro 'PIN_FUNC_SELECT'
i2s.c:155:42: error: 'FUNC_I2SO_DATA' undeclared (first use in this function)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0RXD_U, FUNC_I2SO_DATA);
i2s.c:155:2: note: in expansion of macro 'PIN_FUNC_SELECT'
i2s.c:156:42: error: 'FUNC_I2SO_WS' undeclared (first use in this function)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_I2SO_WS);
i2s.c:156:2: note: in expansion of macro 'PIN_FUNC_SELECT'
i2s.c:157:41: error: 'FUNC_I2SO_BCK' undeclared (first use in this function)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, FUNC_I2SO_BCK);
i2s.c:157:2: note: in expansion of macro 'PIN_FUNC_SELECT'
make[1]: *** [.output/eagle/debug/obj/i2s.o] Error 1
make[1]: Leaving directory `/mnt/Share/esp_iot_sdk_v1.5.1/i2s/driver'
make: *** [.subdirs] Error 2
