What SPI flash settings to use for ESP-wroom-02 module?
helpme
Postby helpme » Mon Feb 15, 2016 5:03 pm
Hi Espressif,
I bought your ESP-wroom-02 module http://espressif.com/en/products/wroom/
What are the correct SPI parameters that I should use in the Makefile for your sdk sample app?
Currently, this is what I use.
SPI_SPEED ?= 40
SPI_MODE ?= dio
SPI_SIZE_MAP ?= 4
It seems to work fine. However, the confusing part is that when I use SPI_MODE ?= qio, the module also works fine. Which exactly are the correct parameters?
Thank you.
Re: What SPI flash settings to use for ESP-wroom-02 module?
Postby ESP_Faye » Tue Mar 01, 2016 2:25 pm
Yes, it can run as DIO or QIO, it depends on your need.
