SSL handshake failure (Fatal exception 29)
jdmrcq
Postby jdmrcq » Fri Feb 19, 2016 6:55 pm
Hi all,
I wrote a simple SSL application that sends HTTPS requests to a server. After thousands of requests, the application crashes during handshake:
client handshake start.
E:M 1032
Fatal exception 29(StoreProhibitedCause):
epc1=0x4000e1b2, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000004, depc=0x00000000
 ets Jan  8 2013,rst cause:2, boot mode:(1,6)
 ets Jan  8 2013,rst cause:4, boot mode:(1,6)
wdt reset
At this point nothing run anymore, the application didn't restart properly.
I tried to disassemble my program with objdump to see which instruction fail at epc1=0x4000e1b2. But this address seems to be in BOOT ROM section according to http://esp8266-re.foogod.com/wiki/Memory_Map#bootrom.
Another point is that after every request I get the error:
client's data invalid protocol
Error: SSL error 3
But it doesn't stop program execution. I have no idea what these errors means as they are printed by SDK and I didn't find any documentation about it.
I have no solution, could anyone help?
Re: SSL handshake failure (Fatal exception 29)
Postby ESP_Faye » Wed Mar 02, 2016 2:51 pm
Please have a try with the attachment based on ESP8266_NONOS_SDK_V1.5.1.
libssl_ESP8266_NONOS_SDK_V1.5.1.zip
(160.52 KiB) Downloaded 733 times
DarkSide
Postby DarkSide » Fri Jun 09, 2017 11:49 pm
SDK 2.0.0 - having same problem from time to time, it's not reproducing constantly but definetelly related to SSL
DomalysAlexis
Postby DomalysAlexis » Tue Dec 05, 2017 11:39 pm
Hi all,
I have exactly same issue with SDK 2.1.0.
Is it plan to have a fix quickly for this issue?
Users browsing this forum: No registered users and 291 guests
