Get RSSI when in AP Mode - Problem
vonny232
Postby vonny232 » Mon Feb 29, 2016 9:15 pm
I am working on firmware for the AI-Thinker ESP-06E variant.
I am using SDK 1.4.0 but with an older AT Command parser combined with the SDK so we could create some custom AT Commands.
Anyway, I have an unusual problem.
When we put the ESP module into AP Mode (using a webserver to send/receive testing and configuration details), the RSSI command wifi_station_get_rssi() does not work unless the module has successfully connected to a WIFI router at least once.
If I try and get the RSSI when in AP mode with a freshly programed ESP-06E, the function returns 31 (Error).
if I connect to a router in Station mode, then disconnect and get RSSI in AP mode, the function works OK.
I know this is complicated to describe, but it is a major problem for us because it means we cannot test the WIFI antenna Signal Strength during production test.
Any ideas?
Re: Get RSSI when in AP Mode - Problem
Postby ESP_Faye » Mon Mar 07, 2016 4:21 pm
Can the "WiFi analyzer" help ? It can analyze the APs nearby.
