[Solved] 请教:OTA时,由USER2.BIN更新USER1.BIN出错,无法启动.
xyz769
Postby xyz769 » Tue Mar 01, 2016 10:06 pm
BOOT.BIN用的1.5版的.
SDK用的1.5.2,由USER1.BIN更新USER2.BIN时正常,重启后能运行到USER2.BIN,但随即从USER2.BIN更新USER1.BIN时,FLASH超时,触发WDT RESET ,系统一直报错,无法启动.重新通过串口刷一次USER1.BIN,重启后是从USER2.BIN启动.相关日志如下:
第一次启动信息:
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1 @ 1000
SDK version:1.5.2(80914727)
OAT升级USER2.BIN部分日志:
HEAD /agent/update/user2.bin HTTP/1.1
Host: 192.168.1.140
Connection: close
Content-Length: 0
Cache-Control: max-age=0
Accept: */*
User-Agent: Mozilla/5.0 (Windows NT 5.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/47.0.2526.106 Safari/537.36
Accept-Encoding: gzip, deflate
Accept-Language: zh-CN,zh;q=0.8,en;q=0.6,zh-TW;q=0.4
pusrdata = HTTP/1.1 200 OK
Server: Apache-Coyote/1.1
Accept-Ranges: bytes
ETag: W/"236356-1456840445390"
Last-Modified: Tue, 01 Mar 2016 13:54:05 GMT
Content-Length: 236356
Date: Tue, 01 Mar 2016 13:55:07 GMT
Connection: close
sumlength = 236356
sec_block 58
..........................................................upgrade_get_sum_disconcb 41696
erase sector=129 ok
erase sector=130 ok
erase sector=131 ok
erase sector=132 ok
erase sector=133 ok
执行OAT升级USER2.BIN时,启动信息:
totallen = 236356
flash_crc = 896672383
img_crc = 896672383
upgrade_check
upgrade successful
reboot to use2
state: 5 -> 0 (0)
rm 0
pm close 7
del if0
usl
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user2 @ 81000
再次执行OAT,升级USER1.BIN日志信息:
HEAD /agent/update/user1.bin HTTP/1.1
Host: 192.168.1.140
Connection: close
Content-Length: 0
Accept: */*
ETag: W/"236356-1456840451625"
Last-Modified: Tue, 01 Mar 2016 13:54:11 GMT
Date: Tue, 01 Mar 2016 13:55:28 GMT
Connection: close
sumlength = 236356
sec_block 58
erase sector=1 ok
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : QIO
Fatal exception (0):
epc1=0x40201a18, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
后面一直是这个错误信息,重新上电直接报这个错误,无法启动.
通过串口单独烧录USER1.BIN到0X01000后,启动成功,启动信息:
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : QIO
don't use rtc mem data
启动成功.
Re: 请教:OTA时,由USER2.BIN更新USER1.BIN出错,无法启动.
Postby ESP_Faye » Wed Mar 02, 2016 10:16 am
您好,
从您的现象描述看来,无论运行 user1.bin 还是 user2.bin,您的程序擦写的都是 user2 的区域 (0x81000),这样导致运行 user2 时将正在运行的固件擦掉了而无法启动。
xyz769
Postby xyz769 » Wed Mar 02, 2016 3:38 pm
感谢您的回复,我的调用函数如下:
LOCAL void ICACHE_FLASH_ATTR user_webclient_upgrade_rsp(void *arg) {
struct upgrade_server_info *server = arg;
if (server->upgrade_flag == true) {
PERR("upgrade successful\n");
system_upgrade_reboot();
} else {
PERR("upgrade failed\n");
os_free(server->url);
server->url = NULL;
os_free(server);
server = NULL;
LOCAL void ICACHE_FLASH_ATTR user_webclient_begin_upgrade(void) {
struct upgrade_server_info *upsvc = (struct upgrade_server_info *) os_zalloc(sizeof(struct upgrade_server_info));
uint8 * user_bin=(uint8 *)os_zalloc(100);
upsvc->pespconn = &TcpClient;
upsvc->port = WEB_PORT;
upsvc->check_cb = user_webclient_upgrade_rsp;
upsvc->check_times = 120000;
os_memcpy(upsvc->ip, &tcp_server_ip, 4);
upsvc->url = (uint8 *) os_zalloc(512);
//os_bzero(user_bin, 100);
if (system_upgrade_userbin_check() == UPGRADE_FW_BIN1) {
os_sprintf(user_bin, UPDATE_URL, "user2.bin");
} else if (system_upgrade_userbin_check() == UPGRADE_FW_BIN2) {
os_sprintf(user_bin, UPDATE_URL, "user1.bin");
os_sprintf(upsvc->url, HTTP_HEAD_FRAME, "GET", user_bin, &server_url.server_host[0], 0);
os_free(user_bin);
if (system_upgrade_start(upsvc) == false) {
PERR("upgrade is already started\n");
os_free(upsvc->url);
os_free(upsvc);
请帮忙看看这个入口函数有没有问题,谢谢.
xyz769
Postby xyz769 » Wed Mar 02, 2016 3:44 pm
另外,日志提示第二次是在擦除USER1.BIN区域了:
sec_block 58
erase sector=1 ok
erase sector=1 ok ---->0x01000
可是不知什么原因卡住了,并触发了WDT RESET,奇怪的是明明提示只擦了USER1.BIN区域,但USER2.BIN区域却无法启动了.更怪的是,此时用串口重新擦USER2.BIN却不能正常启动USER2.BIN,只有重新擦写USER1.BIN才能让USER2.BIN正常启动.
感觉是BOOTLOADER从USER2.BIN启动时,还是要跳到USER1.BIN中转一圈才回到USER2.BIN中正常执行...
Postby ESP_Faye » Thu Mar 03, 2016 11:08 am
您好,
请确认,user1.bin 和 user2.bin 应该是不同的两个 bin 文件,编译步骤:
1. 编译 user1.bin
2. make clean 清除上次编译生成的临时文件
3. 与步骤 1 中的其他编译选项均一致,区别仅在于选择编译 user2
怀疑您是否在编译时异常,您的 user1.bin 和 user2.bin 其实都是 user1.bin。
或者麻烦提供一下您的 user1.bin 和 user2.bin,我们将协助您分析。
xyz769
Postby xyz769 » Thu Mar 03, 2016 10:26 pm
的确是MAKE的问题,已经搞定了.谢谢.
galaxyobe
Re: [Solved] 请教:OTA时,由USER2.BIN更新USER1.BIN出错,无法启动.
Postby galaxyobe » Thu Mar 24, 2016 6:00 pm
您好!您是怎么样解决的?
