RTOS_SDK 1.4.0 LWIP debug mode
hreintke
Postby hreintke » Fri Mar 04, 2016 9:47 pm
LS,
In the Sming framework we are using the LWIP interface for tcp communication.
After moving from NONOS SDK to RTOS SDK there are issues with IP communication (both on SDK 1.3.0 and 1.4.0)
To further investigate the causes I need to have a LWIP library with DEBUG enabled.
Can you provide a DEBUG enabled library or the necessary information/files to create one myself ?
Kind regards.
hreintke
Re: RTOS_SDK 1.4.0 LWIP debug mode
Postby hreintke » Thu Mar 10, 2016 11:44 pm
Dear Espressif,
Can you please answer the question ? I need to progress in my framework issue solving.
Kind regards.
Postby ESP_Faye » Tue Mar 15, 2016 1:46 pm
LWIP is open source on ESP8266_RTOS_SDK_V1.4.0.
You can enable the debug mode yourself if it is needed.
kakaxi
Postby kakaxi » Tue Mar 15, 2016 2:34 pm
Dear Espressif,
I met a problem!
I download the pacakage sdk1.5.0 from download/file.php?id=989 and unzip the pack failed.Then I download another pacakage sdk1.5.2 from download/file.php?id=1079 and unzip the pack failed,too.Please tell
me how to solve the problem.
The error information is as:
--2016-03-15 14:33:36-- download/file.php?id=989
正在解析主机 bbs.espressif.com (bbs.espressif.com)... 119.9.92.91
正在连接 bbs.espressif.com (bbs.espressif.com)|119.9.92.91|:80... 已连接。
已发出 HTTP 请求,正在等待回应... 200 OK
长度: 2192154 (2.1M) [application/octet-stream]
正在保存至: “esp_iot_sdk_v1.5.0_15_11_27.zip”
100%[=====================================================================================================================================================>] 2,192,154 139KB/s 用时 21s
2016-03-15 14:34:07 (104 KB/s) - 已保存 “esp_iot_sdk_v1.5.0_15_11_27.zip” [2192154/2192154])
unzip -q -o esp_iot_sdk_v1.5.0_15_11_27.zip
warning [esp_iot_sdk_v1.5.0_15_11_27.zip]: 7601 extra bytes at beginning or within zipfile
(attempting to process anyway)
error [esp_iot_sdk_v1.5.0_15_11_27.zip]: start of central directory not found;
zipfile corrupt.
(please check that you have transferred or created the zipfile in the
appropriate BINARY mode and that you have compiled UnZip properly)
make: *** [esp_iot_sdk_v1.5.0/.dir] 错误 3
Postby ESP_Faye » Wed Mar 16, 2016 10:58 am
Sorry that there was something wrong on our BBS, we have fixed it now.
Please try to download it again. If your problem is still unsolved, please feel free to let us know.
kakaxi
Postby kakaxi » Wed Mar 16, 2016 11:12 am
Thanks.It is OK now.
