I am trying to setup a simple server in the port :80 with a esp8266 module.
I flashed it to the most recent version and it seems to work ... but it is like it doesn't respond to request when I access it through the explorer.
The most annoying part for me is about the +CIFS command
It returns the following:
AT+CIFSR
+CIFSR:APIP,"86.186.85.186"
+CIFSR:APMAC,"1a:fe:34:9b:c3:83"
+CIFSR:STAIP,"102.106.51.178"
+CIFSR:STAMAC,"c0:ca:41:00:47:40"
`My network is 192.168.1.X , 255.255.255.0, 192.168.1.1`
According to this thread I found (http://www.esp8266.com/viewtopic.php?f=6&t=5791)
>Station (STA) is when your ESP is connecting to your home wifi.
>Access Point (AP) is when your ESP is broadcasting wifi for you to connect to.
If I execute a ping on the `86.186.85.186` is ok.
Haciendo ping a 86.186.85.186 con 32 bytes de datos:
Respuesta desde 86.186.85.186: bytes=32 tiempo=67ms TTL=51
Estadísticas de ping para 86.186.85.186:
Paquetes: enviados = 4, recibidos = 4, perdidos = 0
(0% perdidos),
Tiempos aproximados de ida y vuelta en milisegundos:
Mínimo = 67ms, Máximo = 67ms, Media = 67ms
Command sequence:
AT
AT+RST
WIFI DISCONNECT
ets Jan 8 2013,rst cause:1, boot mode:(3,0)
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 4Mbit(256KB+256KB)
jump to run user1 @ 1000
rlŽ‚rlŒžâ
ready
AT+GMR
AT version:0.60.0.0(Jan 29 2016 15:10:17)
SDK version:1.5.2(80914727)
compile time:Jan 29 2016 19:07:08
AT+CWMODE?
+CWMODE:2
AT+CWMODE_CUR=3
AT+CWJAP_CUR="XXXX","XXXX"
WIFI CONNECTED
WIFI GOT IP
AT+CIFSR
AT+CIPMUX=1
AT+CIPSERVER=1,80
Am I missing something?
[Solved] ESP8266 AT commands to setup a server
