SPI Driver API in RTOS SDK v1.3
Postby esp8266ac » Tue Mar 08, 2016 2:41 pm
RTOS SDKv1.3.0 中提供 SPI Driver API:
• uint32 spi_flash_get_id (void)
Get ID info of SPI Flash.
• SpiFlashOpResult spi_flash_read_status (uint32 ∗ status)
Read state register of SPI Flash.
• SpiFlashOpResult spi_flash_write_status (uint32 status_value)
Write state register of SPI Flash.
• SpiFlashOpResult spi_flash_erase_sector (uint16 sec)
Erase the Flash sector.
• SpiFlashOpResult spi_flash_write (uint32 des_addr, uint32 ∗ src_addr, uint32 size)
Write data to Flash.
• SpiFlashOpResult spi_flash_read (uint32 src_addr, uint32 ∗ des_addr, uint32 size)
Read data from Flash.
而在RTOS SDK Programming Guide中提及:
9. 基本示例:从 Flash 读取数据
(1) Flash 读写数据,要求必须 4 字节对齐。例如,从 Flash 读取数据:
(2) 向 Flash 写入数据同理,要求 4 字节对齐,使用接口 spi_flash_write 即可。
(3) 编译应用程序,生成固件烧录到 ESP8266 硬件模组中。
(4) 硬件模组掉电,切换到运行模式,重新上电,运行应用程序。
Flash Write 一般是要先Read/Backup 有用数据, Erase Sector, 合并备份的数据和要写入的数据,把所有数据写到Flash;
ProgrammingGuide 说 直接使用 spi_flash_write, 难道是spi_flash_write封装了上述功能吗? 还请帮忙澄清一下,谢谢!
Re: SPI Driver API in RTOS SDK v1.3
Postby esp8266ac » Wed Mar 16, 2016 11:55 pm
请帮忙 看一下代码有没有问题,谢谢!
uint8 param_set_entry(uint8 EntryNum, uint16 EntrySize, uint32 *EntryPtr)
uint8 retval;
uint8 retry;
uint16 sect;
uint16 size;
uint32 *buff = NULL;
SpiFlashOpResult result;
if((EntryNum < PARAM_ENTRY_MAX) && (EntrySize <= CONFIG_PARAM_ENTRY_SIZE))
sect = (CONFIG_PARAM_USRSEC_OFFSET + EntryNum * CONFIG_PARAM_ENTRY_SIZE) / CONFIG_SPI_FLASH_SEC_SIZE;
/* Allocate buff for a sector */
if( (PARAM_ENTRY_MAX * CONFIG_PARAM_ENTRY_SIZE) <= CONFIG_SPI_FLASH_SEC_SIZE )
/* There is only 1 sector used, the current Entry locates in the 1st Sector */
size = PARAM_ENTRY_MAX * CONFIG_PARAM_ENTRY_SIZE;
else /* There is only 2 sector used*/
if((EntryNum * CONFIG_PARAM_ENTRY_SIZE) >= CONFIG_SPI_FLASH_SEC_SIZE)
/*the current Entry locates in the 2st Sector*/
size = PARAM_ENTRY_MAX * CONFIG_PARAM_ENTRY_SIZE - CONFIG_SPI_FLASH_SEC_SIZE;
else /*the current Entry locates in the 1st Sector*/
size = CONFIG_SPI_FLASH_SEC_SIZE;
buff = (uint32 *)malloc(size);
if(NULL == buff)
return false;
/*Try to backup Entries to be erased */
retry = CONFIG_PARAM_RETRY;
retval = false;
while(retry)
result = spi_flash_read((sect * CONFIG_SPI_FLASH_SEC_SIZE), buff, (uint32)size);
switch(result)
case SPI_FLASH_RESULT_OK:
retval = true;
retry = 1;
break;
default:
break;;
retry --;
if(false == retval)
goto Failed;
/*Try to erased sector */
retval = false;
while(retry)
result = spi_flash_erase_sector(sect);
switch(result)
retval = true;
retry = 1;
break;
default:
break;;
retry --;
if(false == retval)
goto Failed;
/* Merge Data into buffer */
memcpy((buff + ((EntryNum * CONFIG_PARAM_ENTRY_SIZE) % CONFIG_SPI_FLASH_SEC_SIZE)), EntryPtr, EntrySize);
/*Try to Write Entries to Erased Sector */
retval = false;
while(retry)
result = spi_flash_write((sect * CONFIG_SPI_FLASH_SEC_SIZE), buff, (uint32)size);
switch(result)
retval = true;
retry = 1;
break;
default:
break;;
retry --;
Failed:
if(NULL != buff)
free(buff);
return retval;
return false;
}Who is online
