Strange boot failure
karawin
Postby karawin » Sun Mar 13, 2016 7:07 pm
After a wrong IPR AT command, I broke the software of my brand new ESP8266.
No problem, the flash boot is ok and i flash it with esptool.py. but but...
At power on I receive at 74880 bauds
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : DIO
SPI Flash Size : 8Mbit
jump to run user1
And nothing else.
on reset i receive
And nothing else.
It seems that the flash is read only at power on, and then stop.
I checked many other release with the same results.
My configuration has an external power source at 3.3v and all GPIO 2 in fact) are shifted to VCC or ground for flash.
Have I burned the ESP?
karawin
Re: Strange boot failure
Postby karawin » Tue Mar 15, 2016 7:39 pm
It seems that the flash chip is out of service now. Every -flash_verify fails.
Ok, I give up. A brand new ESP with a dying component.
Its time to change my 2$ board.
Postby ESP_Faye » Wed Mar 16, 2016 10:31 am
Could you have a try with our ESP Flash Download Tool http://bbs.espressif.com/viewtopic.php?f=57&t=433?
Here is our latest AT firmware http://bbs.espressif.com/viewtopic.php?f=46&p=5964#p5964.
karawin
Postby karawin » Thu Mar 17, 2016 4:55 am
I tried every download tools including yours.
But I had a doubt and needed a verify feature.
This verify worked at the beginning, but now it fails.
Really, i think that the flash chip has gone...
https://www.dropbox.com/s/bztxtxpn6xbnvve/2016-03-13%2011.54.23.jpg?dl=0
