SDK0.9.5 + AT 0.21 bug, when using server with multiple conn
rgregor
Postby rgregor » Tue Feb 10, 2015 6:17 am
I have loaded the new AT bin to my application. And it seems, that what was working before with the AT v. 20 doesn't work now. Can you help? In fact, I have TCP server mode and I am receiving HTTP requests. Seems, that first connection is OK, but when I close the first TCP, I am not able to use the module at all and just receiving BUSY. Please note, that this code fully worked without any single change for all the previous AT releases. Here are the AT commands flow:
wdt reset
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 4Mbit
jump to run user1
rlNÿ
ready
AT+GMR
AT version:0.21.0.0
SDK version:0.9.5
AT+CWJAP?
No AP
AT+CWJAP?
No AP
AT+CWJAP?
No AP
AT+CWMODE=3
AT+CIPMODE=0
AT+CIPMUX=1
AT+CIPSERVER=1,80
AT+CIPSTO=2
0,CONNECT
+IPD,0,248:GET / HTTP/1.1
Accept: text/html, application/xhtml+xml, */*
Accept-Language: cs-CZ
User-Agent: Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/5.0)
Accept-Encoding: gzip, deflate
Host: 192.168.4.1
Connection: Keep-Alive
AT+CIPSEND=0,920
> HTTP/1.0 200 OK
Content-Type: text/html
Connection: close
<html><head><style>body{background-color:#2F4F4F;}p{background-color:orange;font-family:verdana;font-size:120%;}small{color:white;}table{background-color:orange;}</style></head><body><p><a href='/'>Wifi config</a>&nbsp;|&nbsp;<a href='ca'>Device config</a>&nbsp;|&nbsp;<a href='cb'>Sketch upload</a>&nbsp;|&nbsp;<a href='t'>Status</a>&nbsp;|&nbsp;<a href='s'>Control</a></p><FORM action='cc' method='GET'><table><tr><th colspan='2'>WIFI config</th></tr><tr><td>Wifi SSID:</td><td><input name='cs' type='text' maxSize='32' value=''/></td></tr><tr><td>Wifi password:</td><td><input name='cp' type='text' maxSize='64' value=''/></td></tr><tr><td>Static IP addr:</td><td><input name='ci' type='text' maxSize='15' value=''/></td></tr><tr><td colspan='2'><input type='submit' value='Configure'/></td></tr></table></form><small>Version: 1.0.0</small></body></html>
SEND OK
AT+CIPCLOSE=0
0,CLOSED
<---------------------- Any AT command is now responded with busy..... -------------------------------->
0,CONNECT
+IPD,0,325:GET /cc?cs=Bob&cp=LukiKukiBuki123456&ci=192.168.1.30 HTTP/1.1
Referer: http://192.168.4.1/
Host: 192.168.4.1
AT+CIPSEND=0,638
busy p...
0,CLOSED
Will force to restart!!!
wdt reset
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1
phil31
Re: SDK0.9.5 + AT 0.21 bug, when using server with multiple
Postby phil31 » Tue Feb 10, 2015 6:22 am
hi, i notice the same problem here !
after the first reply to a GET request, the ESP8266 seem "halted" .. the reply is always "busy p..."
with the previous AT firmware (0.20) it was working "better" (unstable with unsolicited message sometime, but not hanged !)
i'm really disappointed with this ...
plane to change my mind and use another chip until a working & stable AT firmware is provided !
regards
Postby ESP_Faye » Tue Feb 10, 2015 3:32 pm
Sorry for the inconvenience..
Please try the AT firmware here http://bbs.espressif.com/viewtopic.php?f=13&t=163#p632
And feel free to let us know if you have any question~
rgregor
Postby rgregor » Tue Feb 10, 2015 6:31 pm
Hello, great, it seems that this is now working great! Even now the, when the static IP address is saved in the flash, the woke up and connect from power down is very fast. I am only little bit sad, that the AT firmware is not open source any more. I understand probably your point, that then you will have troubles to support customers, who will not have your original fw, however there cannot be a simple AT command to do e.g. the checksum of the user flash to know, if original fw is there or not?
Are there any plans to e.g. support the webserver in the AT fw? Or at least to e.g. read / write the module flash memory to be able to store there e.g. the webpages?
Postby Her Mary » Mon Feb 16, 2015 11:24 am
