Losing firmware after changing baud rate and pressing reset.
polishdude20
Postby polishdude20 » Wed Mar 16, 2016 8:51 am
I've installed the latest 1.5.2 sdk on my ESP8266-07 and it is working fine at 115200 baud. Even when the power goes out and i reset the unit it still works.
When I switch the baud rate down to 9600 using AT+IPR=9600, it works IF I don't turn off the ESP. If I turn it off then it forgets all my firmware and I have to flash it again.
This is what I get at 76800 baud:
load 0x40100000, len 25968, room 16
tail 0
chksum 0x0c
load 0x3ffe8000, len 2092, room 8
tail 4
chksum 0x6f
load 0x3ffe8830, len 9360, room 4
tail 12
chksum 0x45
csum 0x45
jq+PW*5hY*)Dr
S.
Any suggestions? This only happens when I change my baud rate. I am not forgetting to change my baud rate in my serial monitor either so that's not the problem.
Re: Losing firmware after changing baud rate and pressing reset.
Postby ESP_Faye » Wed Mar 16, 2016 10:35 am
Sorry that your AT firmware is not provided by our company, we do not have command AT+IPR.
Would you like to have a try with our latest AT firmware ? http://bbs.espressif.com/viewtopic.php?f=46&p=5964#p5964
Please download the bin files into flash through ESP Flash Download Tool. http://bbs.espressif.com/viewtopic.php?f=57&t=433
