求助:esp_iot_sdk_1.5.1 OTA升级遇到的问题
nkahdoh
Postby nkahdoh » Wed Mar 23, 2016 11:50 am
按照sdk里的示例测试的升级功能,前几次网络能成功,以后就不再成功了,串口打印如下:
system_upgrade_start
upgrade_connect 38120
MQTT: Sending, type: 3, id: 0000epc1=0xc0000f74, epc2=0x00000000, epc3=0
x00000000, excvaddr?x0000000
upgrade_connect_cb
GET /download/user2.4096.new.4.bin HTTP/1.0
Host: 192.168.1.234:80
Connection: keep-alive
Cache-Control: no-cache
User-Agent: Mozilla/5.0 (Windows NT 5.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/30.0.1599.101 Safari/537.36
Accept: */*
HEAD /download/user2.4096.new.4.bin HTTP/1.0
Connection: close
Accept: */*
te,sdch
STATION_GOT_IP
yijingyou I
P le STATIONAP_MODE
pusrdata = HTTP/1.1 200 OK
Server: MyWebServer/3.5.52 Unicode (By TGY)
Date: We
d, 23 Mar 2016 03:43:03 GMT
Accept-Rang
es: bytes
Last-Modified: Wed,
23 Mar 2016 02:56:46 GMT
Content-Type: octe
t-stream
Content-Length: 311380
ETag: "/download/user2.4096.new.4.b
in:Wed, 23 Mar 2016 02:56:46 GMT"
Connection: Keep-Ali
ve
sumlength = 311380
sec
_block 77
.................TCP: Sent
MQTT: Published
upgrade_get_sum_disconcb 36160
erase sector=129 ok
erase sector=130 ok
erase sector=131 ok
erase sector=132 ok
erase sector=133 ok
erase sector=134 ok
erase sector=135 ok
erase sector=136 ok
erase sector=137 ok
ase sector=138 ok
erase晬呀甚139 ok
erase sector=140 ok
erase sector=141 ok
erase sector=142 ok
00000
Fatal exception?(IllegalInstructionCause):
0, depc=0x00000000
se):
epc1=0xc0000f74, epc2=0x00000000, epc3=0x00000000, excvaddr?x000000
00, depc=0x00000000
epc1=0xc0000f74, epc2=0x00000000, epc3=0x00000000, excvaddr?x00000000, depc=0x00000000
, epc3=0x00000000, excvaddr?x00000000, d?x00000000
e
epc1=0xc000
epc1
tructionCause):
ep
Fatal exception?(I
epc1=0xc0
以上出错代码是啥意思,该如何处理?多谢!
galaxyobe
Re: 求助:esp_iot_sdk_1.5.1 OTA升级遇到的问题
Postby galaxyobe » Thu Mar 24, 2016 3:27 pm
我的也是这样,开始可以升级成功,后来都是失败的多!
Postby ESP_Faye » Thu Mar 24, 2016 5:07 pm
您好,
麻烦提供您的完整测试代码,我们将安排测试复现,以供查证。
galaxyobe
Postby galaxyobe » Thu Mar 24, 2016 6:25 pm
upgrade_connect 35160
upgrade_connect_cb
GET /upgrade/user2.bin HTTP/1.1
Host: 192.168.2.17:2828
Accept: */*
Authorization: deviceId:,productKey:
HEAD /upgrade/user2.bin HTTP/1.1
Connection: close
Accept: */*
Content-Length: 290548
Accept-Ranges: bytes
Server: HFS 2.3g
Set-Cookie: HFS_SID_=0.954295650823042; path=/; HttpOnly
Last-Modified: Thu, 24 Mar 2016 10:16:44 GMT
Content-Disposition: attachment; filename="user2.bin";
sumlength = 290548
sec_block 71
.......................................................................upgrade_get_sum_disconcb 33504
erase sector=257 ok
erase sector=258 ok
erase sector=259 ok
erase sector=260 ok
erase sector=261 ok
erase sector=262 ok
erase sector=263 ok
erase sector=264 ok
erase sector=265 ok
erase sector=266 ok
erase sector=267 ok
erase sector=268 ok
erase sector=269 ok
erase sector=270 ok
erase sector=271 ok
erase sector=272 ok
erase sector=273 ok
erase sector=274 ok
erase sector=275 ok
erase sector=276 ok
erase sector=277 ok
erase sector=278 ok
erase sector=279 ok
erase sector=280 ok
erase sector=281 ok
erase sector=282 ok
erase sector=283 ok
erase sector=284 ok
erase sector=285 ok
erase sector=286 ok
erase sector=287 ok
erase sector=288 ok
erase sector=289 ok
erase sector=290 ok
erase sector=291 ok
erase sector=292 ok
erase sector=293 ok
erase sector=294 ok
erase sector=295 ok
erase sector=296 ok
erase sector=297 ok
erase sector=298 ok
erase sector=299 ok
erase sector=300 ok
erase sector=301 ok
erase sector=302 ok
erase sector=303 ok
erase sector=304 ok
erase sector=305 ok
erase sector=306 ok
erase sector=307 ok
erase sector=308 ok
erase sector=309 ok
erase sector=310 ok
erase sector=311 ok
erase sector=312 ok
erase sector=313 ok
erase sector=314 ok
erase sector=315 ok
erase sector=316 ok
erase sector=317 ok
erase sector=318 ok
erase sector=319 ok
erase sector=320 ok
erase sector=321 ok
erase sector=322 ok
erase sector=323 ok
erase sector=324 ok
erase sector=325 ok
erase sector=326 ok
erase sector=327 ok
ALL=71 sectors erase ok!
upgrade_connect_cb
Accept: */*
Connection: close
Accept: */*
sumlength = 290548
upgrade file download start.
totallen = 1460
totallen = 2920
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 80MHz
SPI Mode : DOUT
SPI Flash Size & Map: 16Mbit(1024KB+1024KB)
jump to run user1 @ 1000
don't use rtc mem data
卡顿下就复位了,是什么原因呢?
galaxyobe
Postby galaxyobe » Fri Mar 25, 2016 9:48 am
您好,这个是程序,删除了很多功能,还是有时候会卡顿,都不知道是什么原因?
测试命令
下载
curl -X POST -H "Content-Type:application/json" http://192.168.2.11/upgrade?command=start
重启
curl -X POST -H "Content-Type:application/json" http://192.168.2.11/upgrade?command=reset
web.rar
(91.84 KiB) Downloaded 852 times
Postby ESP_Faye » Fri Mar 25, 2016 10:18 am
您好,
您提供的测试代码,缺少了头文件,无法成功编译。麻烦提供可以编译成功的完整测试代码。
galaxyobe
Postby galaxyobe » Fri Mar 25, 2016 11:08 am
您好,我这么编译一下,可以通过了,重新上传了一份!
web.rar
(91.84 KiB) Downloaded 905 times
Postby ESP_Faye » Fri Apr 01, 2016 5:11 pm
您好,
测试您提供的代码,反复升级 20 次,并未出现异常。
建议您更新到 ESP8266_NONOS_SDK_V1.5.2 看是否还有问题?
我们测试使用的服务器是 MiniWebServer,您可以下载测试 http://bbs.espressif.com/viewtopic.php?f=51&t=732。
Users browsing this forum: No registered users and 239 guests
