wdt reset when connect the router which not broadcast ssid
Postby xyuz » Wed Feb 11, 2015 9:18 pm
wdt reset when connect the router which not broadcast ssid, and also often not found the ssid.
my program is base on sdk 0.9.5.
this is the log:
WifiJoinAp[136]:ssid:MERCURY_2.4G_8ACF auth:4 passwd:a12345678
scandone
add 0
aid 1
pm open phy_2,type:2 0 0
cnt
beacon timeout
rm mismatch
pm open phy_2,type:2 7 0
pm.c 810
wdt reset
this is the code:
wifi_station_disconnect();
ETS_UART_INTR_DISABLE();
if(!wifi_station_set_config(&staConfig))
SysLog("wifi_station_set_config fail.");
ETS_UART_INTR_ENABLE();
return 0;
if(!wifi_station_connect())
SysLog("wifi_station_connect fail");
return 0;
this is the log:
scandone
add 0
aid 1
cnt
beacon timeout
rm mismatch
pm.c 810
wdt reset
this is the code:
return 0;
return 0;
Re: wdt reset when connect the router which not broadcast ss
Postby ESP_Faye » Thu Feb 12, 2015 11:47 am
Sorry that I can't replicate your problem, my test code is as the attachment..
Could you offer us more information to debug ? Does this problem only replicate on specific router ?
- Attachments
- user_main.zip
- (942 Bytes) Downloaded 459 times
Postby xyuz » Thu Feb 12, 2015 3:23 pm
@Espressif_Faye
OK, I found the problem is that before connect
I call wifi_station_scan with cfg show_hidden = 1 to scan ssid.
when I set show_hidden = 0 erverthing is ok.
this is my test code you can have a try.
tks.
tks.
- Attachments
- user_main.c.zip
- (1.1 KiB) Downloaded 453 times
Postby ESP_Faye » Sun Feb 15, 2015 4:02 pm
Please try it with our latest SDK http://bbs.espressif.com/viewtopic.php?f=7&t=205
Users browsing this forum: No registered users and 80 guests
