client SSL connection/certs
Postby narayan » Wed Mar 30, 2016 6:04 am
The I have generated private certificate and key for the device ( DER format and created the esp_cert_private_key.bin)
I used the make_cert.py tool (in the client-cert folder of the TLS_BiDirectVerif_Demo.zip) to
generate the ".bin" file - which I flashed into sector 2 of the flash (offset 8192).
The CA is private (self generated), and the cert is signed using this CA Key
Before using the espconn_secure_connect (), I use:
espconn_secure_set_size ()
espconn_secure_cert_req_enable (2) /* the private_key.bin file is in flash sector 2 <offset 8192> */
I get messages:
private_key: 260
certificate: 20e
the file is not a PEM file
However I see in the examples that was provided that you use DER outfor for the certificates.
Please help
narayan
Re: client SSL connection/certs
Postby ESP_Faye » Wed Apr 06, 2016 10:43 am
"the file is not a PEM file", in your case, it is a DER file, so it is not a PEM file. This is not a problem, we can also support DER file.
Sorry for the misunderstanding, we will revise this log.
Postby sslpia » Thu Jul 14, 2016 10:35 pm
Could you please share the 'TLS_BiDirectVerif_Demo.zip' TLS Bi Directional Verification Demo example file as I am not able to find it anywhere.
I am getting the below error:
Please load authenticate certificateThanks,
Kantesh
Postby sslpia » Fri Jul 15, 2016 9:14 pm
I was able to find the demo project files at http://bbs.espressif.com/download/file.php?id=1292, and able to proceed ahead with getting the espconn_secure_ca_enable(ESPCONN_CLIENT, 0x3B) and espconn_secure_cert_req_enable(ESPCONN_CLIENT, 0x3A) separately, i.e. when only espconn_secure_ca_enable() is called or only espconn_secure_cert_req_enable() is called. But when I enable both the functions, the ESP 8266 is failing to connect to MQTT Broker giving the same error as before:
Please load authenticate certificateThis may mean that it is not able to find the "esp_ca_cert.bin" file. Can someone help me out?
Thanks,
Kantesh
Postby sslpia » Wed Sep 14, 2016 3:33 pm
This is to help others who are stuck in a similar problem as us.
Earlier, we were using 0x3b for storing the ca_cert binary file and 0x3a for storing the private_key bin file. It turns out that in our setup, we had to use 0x3e for storing the private_key bin file. So in case you are facing a similar problem, check the available memory address space with your version of ESP8266 and try other possible memory locations.
Thanks!
Postby narayan » Thu Oct 06, 2016 1:15 am
Much happier with it, and it actually works with the TLS version & Ciphers that I needed to support.
BTW - This also goes for the espconn abstraction that is provided. Use LWIP directly - Much more control.
Narayan
Users browsing this forum: No registered users and 335 guests
