Precise timing needed (ex. for IR decoding)
Postby piotrva » Sat Feb 14, 2015 6:52 am
The os_timer has a resolution of one ms - it is too much for more precise operations, like IR signal (RC5 etc.) decoding.
Is there any way to get an interrupt at 50us resolution or to get a tick count at 50us resolution?
Now I am to design an IR signal repeater (aka universal IR pilot controlled by network) and I do not want to use any extra components (ex. microcnotroller, external timer).
Kind regards
Peter
Re: Precise timing needed (ex. for IR decoding)
Postby jcmvbkbc » Sat Feb 14, 2015 8:48 pm
piotrva wrote:Is there any way to get an interrupt at 50us resolution or to get a tick count at 50us resolution?
You can read CCOUNT special register. It increments every clock tick, i.e. every 12.5ns with 80MHz clock.
You can read it with the following function:
static inline unsigned get_ccount(void)
unsigned r;
asm volatile ("rsr %0, ccount" : "=r"(r));
return r;
Postby piotrva » Sat Feb 14, 2015 11:40 pm
Postby costaud » Sun Feb 15, 2015 11:43 am
piotrva wrote:Thank you for the answer - it can be a kind of workaround - of course faster timer interrupt would be better, but maybe I will manage to capture IR data using this data & GPIO interrupt & timer interrupt as idle guard.
uint32 system_get_time(void); CAN provide a relative time count in us. Use it to get the expire between two gpio interrupt .
Postby piotrva » Sun Feb 15, 2015 6:35 pm
#ifdef USE_US_TIMER
#define os_timer_arm_us(a, b, c) ets_timer_arm_new(a, b, c, 0)
#endif
#define os_timer_arm(a, b, c) ets_timer_arm_new(a, b, c, 1)Will test it.
Postby piotrva » Sun Feb 15, 2015 10:18 pm
EDIT:
Finally I decided to use STM32F05x as a IR controller - the ESP's PWM cannot achieve 26/38/40kHz and as I do not want to do it with os_delay_us() i will use STM32 as a slave SPI.
Maybe in next SDK's release there will be an option to generate interrupts at us resolution.
Postby rudi » Thu Mar 05, 2015 10:42 pm
jcmvbkbc wrote:piotrva wrote:Is there any way to get an interrupt at 50us resolution or to get a tick count at 50us resolution?
You can read it with the following function:Code: Select all
unsigned r;
return r;
yes, played last time with this,
http://www.mikrocontroller.net/topic/358654#new
@jcmvbkbc
do you know how much / when overflow ( register bit ) can read , too?
have me a interupt for this?
can we trigger this?
static inline unsigned get_ccount(void);
unsigned r;
return r;
void user_init(void)
while(1)
char ticks1 [32];
char ticks2 [32];
unsigned tick1;
unsigned tick2;
unsigned tickdiff;
tick1 = get_ccount(); // Spezial Register CCOUNT call and save
tick2 = get_ccount(); // Spezial Register CCOUNT call and save
tickdiff = tick2 - tick1; // how much ticks was used
// 1. Register CCOUNT formated transfer to Variable
os_sprintf(ticks1, "%lu", tick1);
// 2. Register CCOUNT formated transfer to Variable + Diff Value
os_sprintf(ticks2, "%lu %lu", tick2, tickdiff);
// ich hab neben dem OLED am SPI auch ein MCP23S17 über SPI am ESP8266
// und betreibe ein einfaches 16 Zeichen x 2 Display daran
// daher ganz simple LCD Ausgabe anstatt Uart
// i have used a MCP23S17 ( SPI Portexpander ) with ESP8266 and use a 8bit LCD for Display
// LCD output for ticks, uart0 for Debug prints
lcdCmd(clearDisplay); // LCD Command Clear Display
lcdGoto(0); // LCD Command Go Postion 0
lcdWriteString(ticks1); // LCD Print Register CCOUNT Total Ticks
lcdGoto(0x40); // LCD Command Go Postion 0x40 (second row)
lcdWriteString(ticks2); // LCD Print Register CCOUNT total Ticks
os_delay_us(10 *1000*1000); // Pause : for me to read value at LCD
lcdCmd(ClearDisplay); // LCD Command Clear Display
} // while
} // user_init
little playing how good optimize compiler..
tick1 = get_ccount(); // Spezial Register CCOUNT Abruf und Übertrag
os_delay_us(1);
tick2 = get_ccount(); // Spezial Register CCOUNT Abruf und Übertrag
tickdiff = tick2 - tick1; // Wieviel Ticks verbraucht
// tickdiff 122
os_delay_us(2);
//tickdiff 194
makes fun
os_delay_us(1);
os_delay_us(1);
// tickdiff 243
1 Mikrosekunden [µs] = 1 000 Nanosekunden [ns]
http://www.einheiten-umrechnen.de/einheiten-rechne...
test 1
one delay 1µs between = 122 ticks
122 ticks zu je 12.5 ns = 1525 µs
./. + 525 µs
test 2
one delay 2µs between = 194 ticks
144 ticks zu je 12.5 ns = 1800 µs
./. - 200 µs
test 3
2 delays with each delay 1µs between = 243 ticks
243 ticks zu je 12.5 ns = 3037,5 µs
./. + 1037.5 µs
more tests:
http://www.mikrocontroller.net/topic/358654#4014599
best wishes
- Attachments
- _1_praezisestimingccount_controll_system_get_time.jpg (32.79 KiB) Viewed 22780 times
- _1_praezisestimingccount_controll_system_get_time_ASM.jpg (47.85 KiB) Viewed 22780 times
問候飛出去的朋友遍全球魯迪
Postby jcmvbkbc » Fri Mar 06, 2015 12:58 am
rudi wrote:@jcmvbkbc
I'm not sure what you're asking, my guess is the questions are
- how long is CCOUNT SR? -- it's 32 bits
- is overflow of CCOUNT detectable? -- no, there's nothing that can tell you about an overflow. No interrupt, no overflow bit.
- is there an interrupt for CCOUNT? Yes, there is a number of CCOMPARE SRs. You can write a value there and then an IRQ will be raised once CCOUNT reaches that value.
For more details please see xtensa ISA book (e.g. http://0x04.net/~mwk/doc/xtensa.pdf ), 4.4.6 Timer interrupt option.
Postby rudi » Fri Mar 06, 2015 3:43 am
jcmvbkbc wrote:rudi wrote:@jcmvbkbc
ok, i take %lu for this 32bit value
ok, i understand
this is the point, txs,
then thinked right,
i helped me with primitive counter and compare the ticks time to time
i have try to make a interupt to a variable , if change , then trigger
i was not sure, is there an interupt or other
thank you!
ok - yes know from the book - will study the point again and try to go on over CCOMPARE SRs and IRQ's
thank you jcmvbkbc!
btw,
if you have an example for CCOMPARE SRs and IRQ's like you think how to do this will helpfull.
i will try too - will update here if i have a functionally work
Best wishes!
rudi
btw
i test, because was searching a trigger, counter, overflow...
with this as primitive code
and note all values in a shema
t1 = system_get_time(); // API get time
// start
tick1 = get_ccount(); // Spezial Register CCOUNT get and save
while (mtick < 10 )
asm ("nop");
mtick++;
t2 = system_get_time(); // API get time
tickdiff = tick2 - tick1; // How much Ticks used
and my shema was
"loops" x 2 x 2 = value + while "loops - 1 " = ticks
so i test..
while (mtick < 30 )
30 x 2 x 2 = 120 + while 30 - 1 = 149
Bingo! calculated was right..
40 x 2 x 2 = 160 + while 40 - 1 = 199
Bingo!
50 x 2 x 2 = 200 + while 50 - 1 = 249
Bingo!
60 x 2 x 2 = 240 + while 60 - 1 = 299
Bingo!
70 x 2 x 2 = 280 + while 70 - 1 = 349
Bingo!
80 x 2 x 2 = 320 + while 80 - 1 = 399
Bingo!
90 x 2 x 2 = 360 + while 90 - 1 = 449
Bingo!
100 x 2 x 2 = 400 + while 100 - 1 = 499
UPS! calculated was 499 but ticks was 598
so i have think, have we a overrun / trigger ?
so i make step by step
in ( ) this is the calculated soll
91 = 454 ticks (91*2*2+while 91-1=454)
92 = 459 ticks (92*2*2+while 92-1=459)
93 = 464 ticks (93*2*2+while 93-1=464)
94 = 469 ticks (94*2*2+while 94-1=469)
95 = 474 ticks (95*2*2+while 95-1=474)
~~~~~~~~~~~~~~~ ok ~~~~~~~~~~~~~
then..
96 = 574 ticks (96*2*2+while 96-1=479)
97 = 580 ticks (97*2*2+while 97-1=484)
98 = 586 ticks (98*2*2+while 98-1=489)
99 = 592 ticks (99*2*2+while 99-1=494)
100 = 598 ticks (100*2*2+while 100-1=499)
in this case allways 6 ticks more like value before
in paste time, allways 5 ticks more.
between 95 and 96 loops there is a swap / more ticks
96*2*2+while 96-1 + 100-1
a overflow from 100 ticks and a difference from 6 ticks
so i test again:
will it be difference if test will be 95 + 96 = 191 loops?
test
190 = 1138 ticks (190*2*2+while 190-1 + 190 - 1 = 1038 )
195 = 1168 ticks (195*2*2+while 195-1 + 195 - 1 = 1168 )
200 = 1198 ticks (200*2*2+while 200-1 + 200 - 1 = 1198 )
1200 ....= 7198 ( = 7198 )
no all ok, but why is a difference betwenn
95 and 96
while.. true ticks ,,,,,,,,,,,,,,,calculated ticks
i have think - then perhabs a possible way for a register bit
sorry for many text
i test many things / think's
問候飛出去的朋友遍全球魯迪
Users browsing this forum: No registered users and 67 guests
