I was trying to compile the webserver included in the sample directory of the official repo, but an error doesn't allow me to go on with it.
I'm using Ubuntu 14.04.2, and the xtensa toolchain has been correctly installed.
Thanks for the support!
alle@alleUbuntu:~/ESP8266_RTOS_SDK/examples/websocket_demo$ ./gen_misc.sh
gen_misc.sh version 20150911
SDK_PATH:
/home/alle/ESP8266_RTOS_SDK
BIN_PATH:
/home/alle/ESP8266_BIN
Please check SDK_PATH & BIN_PATH, enter (Y/y) to continue:
y
STEP 1: use boot_v1.2+ by default
boot mode: new
enter (0/1/2, default 0):
0
ignore boot
generate bin: eagle.flash.bin+eagle.irom0text.bin
enter (0/1/2/3, default 2):
2
spi speed: 40 MHz
enter (0/1/2/3, default 0):
0
spi mode: QIO
0= 512KB( 256KB+ 256KB)
2=1024KB( 512KB+ 512KB)
3=2048KB( 512KB+ 512KB)
4=4096KB( 512KB+ 512KB)
5=2048KB(1024KB+1024KB)
6=4096KB(1024KB+1024KB)
0
spi size: 512KB
spi ota map: 256KB + 256KB
start...
make -C user clean; make -C websocket clean;
make[1]: ingresso nella directory "/home/alle/ESP8266_RTOS_SDK/examples/websocket_demo/user"
rm -f -r .output/eagle/debug
make[1]: uscita dalla directory "/home/alle/ESP8266_RTOS_SDK/examples/websocket_demo/user"
make[1]: ingresso nella directory "/home/alle/ESP8266_RTOS_SDK/examples/websocket_demo/websocket"
make[1]: uscita dalla directory "/home/alle/ESP8266_RTOS_SDK/examples/websocket_demo/websocket"
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../include -I /home/alle/ESP8266_RTOS_SDK/include -I /home/alle/ESP8266_RTOS_SDK/extra_include -I /home/alle/ESP8266_RTOS_SDK/include/espressif -I /home/alle/ESP8266_RTOS_SDK/include/lwip -I /home/alle/ESP8266_RTOS_SDK/include/lwip/ipv4 -I /home/alle/ESP8266_RTOS_SDK/include/lwip/ipv6 -I /home/alle/ESP8266_RTOS_SDK/include/nopoll -I /home/alle/ESP8266_RTOS_SDK/include/spiffs -I /home/alle/ESP8266_RTOS_SDK/include/ssl -I /home/alle/ESP8266_RTOS_SDK/include/json user_main.c
/bin/sh: 2: xtensa-lx106-elf-gcc: not found
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../include -I /home/alle/ESP8266_RTOS_SDK/include -I /home/alle/ESP8266_RTOS_SDK/extra_include -I /home/alle/ESP8266_RTOS_SDK/include/espressif -I /home/alle/ESP8266_RTOS_SDK/include/lwip -I /home/alle/ESP8266_RTOS_SDK/include/lwip/ipv4 -I /home/alle/ESP8266_RTOS_SDK/include/lwip/ipv6 -I /home/alle/ESP8266_RTOS_SDK/include/nopoll -I /home/alle/ESP8266_RTOS_SDK/include/spiffs -I /home/alle/ESP8266_RTOS_SDK/include/ssl -I /home/alle/ESP8266_RTOS_SDK/include/json -o .output/eagle/debug/obj/user_main.o -c user_main.c
make[1]: xtensa-lx106-elf-gcc: comando non trovato
make[1]: *** [.output/eagle/debug/obj/user_main.o] Errore 127
make: *** [.subdirs] Errore 2
