I'm using RTOS 1.4 and I'm stuck trying to use UART1 for debugging purposes.
I added the uart driver provided with the SDK but I cannot see the function to make the UART1 work. This is the content of my user_init function:
void user_init(void)
uart_init_new();
UART_SetBaudrate(UART0,BIT_RATE_115200);
printf("\n\r\nSDK version: %s\n", system_get_sdk_version());
printf("Chip ID: 0x%x\n", system_get_chip_id());
Which is the instruction to send info through the UART1???...OS_PRINT???
Thanks in advance!
UART1 TX
hualaonanxiaoniao
Re: UART1 TX
Postby hualaonanxiaoniao » Wed Apr 27, 2016 4:29 pm
you should see the asscication documents,the name is sdk_programming_guide,in that can found how to make the uart1 as debug function
and that is my demo ,you can see it;
os_install_putc1((void *)uart1_write_char);//this is use uart1 for debug infomations.
Re: UART1 TX
Postby jhinkle » Thu Apr 28, 2016 12:44 am
I did not want to touch UART0 since my GDB stubb was using it.
This is how I implemented UART1
Hope that helps
UART_ConfigTypeDef uart_config;
uart_config.baud_rate = BIT_RATE_115200;
uart_config.data_bits = UART_WordLength_8b;
uart_config.parity = USART_Parity_None;
uart_config.stop_bits = USART_StopBits_1;
uart_config.flow_ctrl = USART_HardwareFlowControl_None;
uart_config.UART_RxFlowThresh = 120;
uart_config.UART_InverseMask = UART_None_Inverse;
UART_ParamConfig(UART1, &uart_config);
UART_SetPrintPort(UART1);
Hope that helps
