]Fatal exception 0(IllegalInstructionCause)
gailu
Postby gailu » Fri Apr 15, 2016 3:45 am
Hi Experts,
I am getting Fatal Exception quite often so can not use code in production. Looking forward to your help. This seems to be happening during spi_flash_erase_sector()
Fatal Exception Details
epc1=0x40205f8a, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1 @ 1000
Checked address in (epc1=0x40205f8a) in .s file and instruction is beqz.n at this address
40205f82:   3109         s32i.n   a0, a1, 12
    if(SPI_FLASH_RESULT_OK != spi_flash_erase_sector(SWITCH_STATUS_SECTOR))
40205f84:   f40901           l32r   a0, 40202fa8 <system_get_checksum+0x34>
40205f87:   0000c0           callx0   a0
40205f8a:   328c         beqz.n   a2, 40205f91 <write_switchstatus_sector+0x19>
        LOG(("ERROR: %s:%d\r\n",__FILE__,__LINE__));
        return ERROR;
40205f8c:   f27c         movi.n   a2, -1
40205f8e:   000946           j   40205fb7 <write_switchstatus_sector+0x3f>
Re: ]Fatal exception 0(IllegalInstructionCause)
Postby ESP_Faye » Mon Apr 18, 2016 8:52 pm
You can print the "SWITCH_STATUS_SECTOR" to debug it.
gailu
Postby gailu » Tue May 10, 2016 6:38 pm
Hi Expressif_Faye,
Value of SWITCH_STATUS_SECTOR 120. Can you please let me know what this value is related to IllegalInstructionCause.
I would like to provide you more input that this does happen only when we try to do very frequent erase and write, if we do slowly we do not see this Fatal Exception.
Postby ESP_Faye » Thu May 12, 2016 3:01 pm
When the exception happened, the SWITCH_STATUS_SECTOR is 120 ?
Sector 120 is located to 480KByte address, will it break your firmware ?
gailu
Postby gailu » Sun May 15, 2016 5:26 am
No, it Will not break my Firmware. We have application specific configuration stored at that address. It works find most of the time, we read and write configuration changes successfully. However when writes are fast (which include erase first) then only we see this crash.
Postby ESP_Faye » Mon May 16, 2016 2:55 pm
1. Which hardware module are you using ? Are you using the ESP-Launcher?
2. Please have a try with the attachment libs based on ESP8266_NONOS_SDK_V1.5.3.
If your problem is still unsolved, please provide your logs and test code, we will help debug it.
lib_dbg_flash_erase1.zip
(613.94 KiB) Downloaded 474 times
