NONOS SDK 1.5.3 not compiling
Blop
Postby Blop » Sat Apr 23, 2016 4:18 am
My app makes use of the UART functions but it does not compile anymore. It seems that there is some conflicts between libat and libdriver.
-With no changes or even if including "driver/uart.h":
xtensa-lx106-elf-gcc  -L../lib -nostdlib -T../ld/eagle.app.v6.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lcrypto -lmain -ljson -lupgrade -lssl -lwps -lsmartconfig -lairkiss user/.output/eagle/debug/lib/libuser.a -lat -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out
user/.output/eagle/debug/lib/libuser.a(user_main.o): In function `msgbroadcast':
/mnt/Share/app/user/user_main.c:145: undefined reference to `uart0_tx_buffer'
user/.output/eagle/debug/lib/libuser.a(user_main.o): In function `bf_sndbroad':
/mnt/Share/app/user/user_main.c:164: undefined reference to `uart0_tx_buffer'
-When modifying the app makefile by adding -ldriver in LINKFLAGS:
xtensa-lx106-elf-gcc  -L../lib -nostdlib -T../ld/eagle.app.v6.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lcrypto -lmain -ljson -lupgrade -lssl -lwps -lsmartconfig -lairkiss -ldriver user/.output/eagle/debug/lib/libuser.a -lat -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out
../lib/libdriver.a(uart.o): In function `uart_tx_one_char':
(.text.uart_tx_one_char+0x8): multiple definition of `uart_tx_one_char'
../lib/libat.a(uart.o):(.text+0xb0): first defined here
../lib/libdriver.a(uart.o): In function `uart0_sendStr':
(.irom0.text+0x1e8): multiple definition of `at_port_print'
../lib/libat.a(uart.o):(.irom0.text+0x228): first defined here
../lib/libdriver.a(uart.o): In function `uart_init':
(.irom0.text+0x224): multiple definition of `uart_init'
../lib/libat.a(uart.o):(.irom0.text+0x290): first defined here
../lib/libdriver.a(uart.o): In function `uart_reattach':
(.irom0.text+0x270): multiple definition of `uart_reattach'
../lib/libat.a(uart.o):(.irom0.text+0x2d0): first defined here
../lib/libdriver.a(uart.o): In function `uart_tx_one_char_no_wait':
(.text.uart_tx_one_char_no_wait+0x8): multiple definition of `uart_tx_one_char_no_wait'
../lib/libat.a(uart.o):(.text+0x238): first defined here
../lib/libdriver.a(uart.o): In function `uart1_sendStr_no_wait':
(.text.uart1_sendStr_no_wait+0x4): multiple definition of `uart1_sendStr_no_wait'
../lib/libat.a(uart.o):(.text+0x25c): first defined here
../lib/libdriver.a(uart.o): In function `uart_rx_intr_disable':
(.text.uart_rx_intr_disable+0x4): multiple definition of `uart_rx_intr_disable'
../lib/libat.a(uart.o):(.text+0x688): first defined here
../lib/libdriver.a(uart.o): In function `uart_rx_intr_enable':
(.text.uart_rx_intr_enable+0x4): multiple definition of `uart_rx_intr_enable'
../lib/libat.a(uart.o):(.text+0x6b0): first defined here
../lib/libdriver.a(uart.o): In function `UART_SetWordLength':
(.irom0.text+0x334): multiple definition of `UART_SetWordLength'
../lib/libat.a(uart.o):(.irom0.text+0x918): first defined here
../lib/libdriver.a(uart.o): In function `UART_SetStopBits':
(.irom0.text+0x360): multiple definition of `UART_SetStopBits'
../lib/libat.a(uart.o):(.irom0.text+0x948): first defined here
../lib/libdriver.a(uart.o): In function `UART_SetLineInverse':
(.irom0.text+0x394): multiple definition of `UART_SetLineInverse'
../lib/libat.a(uart.o):(.irom0.text+0x97c): first defined here
../lib/libdriver.a(uart.o): In function `UART_SetParity':
(.irom0.text+0x3c8): multiple definition of `UART_SetParity'
../lib/libat.a(uart.o):(.irom0.text+0x9b4): first defined here
../lib/libdriver.a(uart.o): In function `UART_SetBaudrate':
(.irom0.text+0x40c): multiple definition of `UART_SetBaudrate'
../lib/libat.a(uart.o):(.irom0.text+0x9f8): first defined here
../lib/libdriver.a(uart.o): In function `UART_SetFlowCtrl':
(.irom0.text+0x458): multiple definition of `UART_SetFlowCtrl'
../lib/libat.a(uart.o):(.irom0.text+0xa44): first defined here
../lib/libdriver.a(uart.o): In function `UART_WaitTxFifoEmpty':
(.irom0.text+0x534): multiple definition of `UART_WaitTxFifoEmpty'
../lib/libat.a(uart.o):(.irom0.text+0xbec): first defined here
../lib/libdriver.a(uart.o): In function `UART_CheckOutputFinished':
(.irom0.text+0x5a0): multiple definition of `UART_CheckOutputFinished'
../lib/libat.a(uart.o):(.irom0.text+0xb40): first defined here
../lib/libdriver.a(uart.o): In function `UART_ResetFifo':
(.irom0.text+0x610): multiple definition of `UART_ResetFifo'
../lib/libat.a(uart.o):(.irom0.text+0xc20): first defined here
../lib/libdriver.a(uart.o): In function `UART_ClearIntrStatus':
(.irom0.text+0x648): multiple definition of `UART_ClearIntrStatus'
../lib/libat.a(uart.o):(.irom0.text+0xc5c): first defined here
../lib/libdriver.a(uart.o): In function `UART_SetIntrEna':
(.irom0.text+0x664): multiple definition of `UART_SetIntrEna'
../lib/libat.a(uart.o):(.irom0.text+0xc78): first defined here
../lib/libdriver.a(uart.o): In function `UART_SetPrintPort':
(.irom0.text+0x698): multiple definition of `UART_SetPrintPort'
../lib/libat.a(uart.o):(.irom0.text+0xca4): first defined here
Re: NONOS SDK 1.5.3 not compiling
Postby ESP_Faye » Tue Apr 26, 2016 11:10 am
Yes. AT commands are sent by a host to ESP8266 through UART, so it has already taken the UART driver.
There are some AT related APIs you can use, please refer to the documentation 2C-ESP8266__SDK__API Guide.
Blop
Postby Blop » Thu Apr 28, 2016 5:15 pm
As you can see in my first code block, the only API function I need is uart0_tx_buffer. I do not understand what I am supposed to do since it cannot be linked anymore, and the API guide is not helping on this point.
I think that something bas been missed when the UART API bas been moved from libat to libdriver.
Postby ESP_Faye » Wed May 04, 2016 9:36 am
What do you want to do with uart0_tx_buffer?
If you need to print some logs, you can use at_port_print instead.
Blop
Postby Blop » Thu May 05, 2016 7:25 am
Actually, the compiler output shown above is a bit misleading: I only call uart0_tx_buffer once in my code.
If I comment out this call, the compile process runs fine.
I just call the function for its intended use: send a buffer, for which one the length to send is already known.
This call is made inside a socket receive callback, in order to easily and directly forward the incoming message buffer to the host microcontroller (and then the ESP autonomously forwards this message to potential softAP clients or broadcasts it to station).
void ICACHE_FLASH_ATTR
recv_cb(void *arg, char *pusrdata, unsigned short len)
//do stuff
   uart0_tx_buffer(pusrdata, len);
//do stuff
I could quite certainly find a workaround, but it would not be the nicest solution. Since the API offers this function to users, for our convenience I still believe that it should be fixed.
Thank you for your help.
