[Solved] Soft-AP DHCP lease time
taribo
Postby taribo » Sun Apr 24, 2016 5:38 pm
I am using the latest AT command FW (AT_V1.0 based on ESP8266_NONOS_SDK_V1.5.3).
I can't set the DHCP lease time correctly.
I am using AT+CWDHCPS_DEF=1,3,"192.168.4.2","192.168.4.3" to set the lease time to 3 minutes. This command returns OK and it should store parameters to flash. But after I restart the ESP8266 module, the DHCP lease time returns to default 120 minutes, as you can see from the serial log below.
After restart, the AT+CWDHCPS_DEF? command returns: +CWDHCPS_DEF:3,192.168.4.2,192.168.4.3
But the AT+CWDHCPS_CUR? command returns: +CWDHCPS_CUR:120,192.168.4.2,192.168.4.3
AT+RST
 ets Jan  8 2013,rst cause:1, boot mode:(3,7)
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
  SPI Speed      : 40MHz
  SPI Mode       : QIO
jump to run user1 @ 1000
rlŽ‚rlŒžâŒ¢þ
ready
AT+CWDHCPS_DEF?
+CWDHCPS_DEF:0,0.0.0.0,0.0.0.0
AT+CWDHCPS_CUR?
+CWDHCPS_CUR:120,192.168.4.2,192.168.4.101
AT+CWDHCPS_DEF?
AT+CWDHCPS_CUR?
+CWDHCPS_CUR:3,192.168.4.2,192.168.4.3
AT+RST
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
  SPI Speed      : 40MHz
  SPI Mode       : QIO
rlŽ‚rlŒžâŒ¢þ
ready
AT+CWDHCPS_DEF?
AT+CWDHCPS_CUR?
AT+GMR
AT version:1.0.0.0(Apr 16 2016 13:02:45)
SDK version:1.5.3(aec24ac9)
compile time:Apr 18 2016 14:20:15
Re: Soft-AP DHCP lease time
Postby ESP_Faye » Mon Apr 25, 2016 3:03 pm
Please have a try with the new AT bin, if your problem is still unsolved, please feel free to let us know.
Sorry for the inconvenience.
AT_test_bin.zip
(279.33 KiB) Downloaded 466 times
taribo
Postby taribo » Tue Apr 26, 2016 3:03 am
Something is not working right. Maybe there is a bug, or maybe I am missing something...
I am using the FW provided by you.
With the default settings, the DHCP server is working fine. Please see below log. In Soft-AP mode, I am connecting 3 Android phones with no problem.
AT+RST
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
  SPI Speed      : 40MHz
  SPI Mode       : QIO
rlŽ‚rlŒžâŒbþ
ready
AT+GMR
AT version:1.0.0.0(Apr 25 2016 14:18:03)
compile time:Apr 25 2016 14:39:42
AT+CWMODE?
+CWMODE:2
AT+CWDHCPS_DEF?
AT+CWDHCPS_CUR?
AT+CWLIF
192.168.4.2,5c:f8:a1:xx:xx:xx
192.168.4.3,60:21:c0:xx:xx:xx
192.168.4.4,20:64:32:xx:xx:xx
Then, I am trying to restrict the number of IPs assigned by DHCP to only 2: 192.168.4.2 and 192.168.4.3, with the lease time 3 minute.
But in this case, I can only connect with first Android phone. As long as the first Android is connected, the second Android never receives an IP from DHCP server inside ESP8266.
I can only connect with the second Android phone after following these steps:
- disconnect the first Android from WiFi
- wait 3 minutes for the second Android to connect to the Soft-AP of the ESP8266
When connected (they are never connected simultaneously) both the first and the second Android, receive the IP: 192.168.4.2.
Is this a normal behavior ?
AT+CWDHCPS_DEF?
AT+CWDHCPS_CUR?
AT+RST
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
  SPI Speed      : 40MHz
  SPI Mode       : QIO
rlŽ‚rlŒžâŒbþ
ready
AT+GMR
AT+CWMODE?
+CWMODE:2
AT+CWDHCPS_DEF?
AT+CWDHCPS_CUR?
AT+CWLIF
192.168.4.2,20:64:32:xx:xx:xx
taribo
Postby taribo » Tue Apr 26, 2016 3:16 am
Also, when I try to restrict the DHCP IP to only one IP: 192.168.4.2, this doesn't work. In this case I am using the command: AT+CWDHCPS_DEF=1,3,"192.168.4.2","192.168.4.2". But after this command, I am able to connect 3 Android phones, with the IPs in the range 192.168.4.2 - 192.168.4.4, as you can see in the log bellow.
AT+RESTORE
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
  SPI Speed      : 40MHz
  SPI Mode       : QIO
rlŽ‚rlŒžâŒb lŒbr|ì bàrb Žàlbìònî€nnâ lbl Œ lŒŽl쌌 Œl l`€nü<0>ŒžâŒb lŒ l b ŒžâŒb lŒb|rlrl
ready
AT+GMR
AT+CWMODE?
+CWMODE:2
AT+CWLIF
AT+CWDHCPS_DEF?
AT+CWDHCPS_CUR?
AT+CWLIF
AT+CWDHCPS_DEF?
+CWDHCPS_DEF:3,192.168.4.2,192.168.4.2
AT+CWDHCPS_CUR?
+CWDHCPS_CUR:3,192.168.4.2,192.168.4.2
AT+RST
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
  SPI Speed      : 40MHz
  SPI Mode       : QIO
rlŽ‚rlŒžâŒ¢þ
ready
AT+GMR
AT+CWMODE?
+CWMODE:2
AT+CWDHCPS_DEF?
AT+CWDHCPS_CUR?
AT+CWLIF
Postby ESP_Faye » Tue Apr 26, 2016 4:30 pm
Please have a try with the attachment.
AT_test_bin2.zip
(279.27 KiB) Downloaded 487 times
taribo
Postby taribo » Wed Apr 27, 2016 2:32 am
It's working fine now :)
Thank you.
