please clarify CTS / RTS lines
phil31
Postby phil31 » Tue Feb 17, 2015 1:26 am
Team,
i use an ESP8266-02 type module.
on this module, the pin 13 ( MTDO ) is DIRECTLY wired to the GND.
the hardwire handshake is enable : i use only the CTS line (input to the ESP8266), to prevent that the ESP8266 send me something when i'm not ready.
when i set CTS = 1 : the ESP stop to send me something : perfect
when i set CTS = 0 : the ESP send me next thing : perfect
now i try to use the RTS line : if the RTS line is active, i don't send anything to the ESP and wait until RTS is not active.
so i cut the line RTS (which is wired to the GND) and wired it to my host CPU.
now, nothing work anymore !!
i expect that the RTS line is an output from the ESP .. so why it is required to link the pin 13 to GND, to work ??
thanks
Phil
georeb
Re: please clarify CTS / RTS lines
Postby georeb » Tue Apr 28, 2015 5:45 pm
Hi Phil,
You said that making pin 13 high (3.3v) pauses the serial output on TX pin.
Is this true for standard versions of the ESP?
Also, how do I enable the handshake please??
I shall look at the RTS problem for you as I also require this function.
Many thanks,
George
