编译esp_iot_sdk_v1.5.3 AT例程的时候出现如下错误,同样的问题不会出现在esp_iot_sdk_v1.4.0。请问是什么原因。
start...
make[1]: Entering directory `/mnt/Share/esp_iot_sdk_v1.5.3/app/user'
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_main.c
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include at_upgrade.c
make[1]: Leaving directory `/mnt/Share/esp_iot_sdk_v1.5.3/app/user'
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-in[*]line-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_main.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/at_upgrade.o -c at_upgrade.c
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_main.o -c user_main.c
xtensa-lx106-elf-ar ru .output/eagle/debug/lib/libuser.a .output/eagle/debug/obj/at_upgrade.o .output/eagle/debug/obj/user_main.o
xtensa-lx106-elf-ar: creating .output/eagle/debug/lib/libuser.a
xtensa-lx106-elf-gcc -L../lib -nostdlib -T../ld/eagle.app.v6.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lcrypto -lmain -ljson -lupgrade -lssl -lwps -lsmartconfig -lairkiss user/.output/eagle/debug/lib/libuser.a -lat -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out
/opt/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .output/eagle/debug/image/eagle.app.v6.out section `.irom0.text' will not fit in region `irom0_0_seg'
esp_iot_sdk_v1.5.3编译问题
Re: esp_iot_sdk_v1.5.3编译问题
Postby ESP_Faye » Tue May 10, 2016 11:35 am
您好,
表示您的代码量太大,存放不下,您可以使用更大容量的 Flash size,编译时也同样选择大容量 Flash size 的选项。
感谢您对 ESP8266 的关注!
section `.irom0.text' will not fit in region `irom0_0_seg'表示您的代码量太大,存放不下,您可以使用更大容量的 Flash size,编译时也同样选择大容量 Flash size 的选项。
感谢您对 ESP8266 的关注!
