AT and IoT_Demo firmware not functioning
Postby Fadi » Sun Nov 02, 2014 11:47 am
I have successfully updated my ESP8266 ESP-01 module yesterday from version 0.91 to 0.922 (downloaded from one of the sites that sells the modules)
I later used the official VM found here, compiled AT firmware and IoT_Demo firmware.
I uploaded the IoT_Demo firmware to the board successfully, only to remember that it may not utilize UART for feedback, so I uploaded the AT firmware
so that I can start testing and do little modifications later.
The module doesn't respond to any AT command and there is no output on the terminal.
I tried changing baudrates and the one that worked was 75000.
I get the following message on uart terminal:
ets Jan 8 2013,rst cause:2, boot mode:(3,4)
load 0x40100000, len 23304, room 16
but uart_init() was set at 115200 as per AT source code, and I didn't change anything in the code, and it compiled without errors.
Can you please help me trouble shoot the problem?
VCC supplied 3.3v
TX/RX are 3.3v TTL levels
CH_PD 3.3v (HIGH)
RST is GROUND
I was only successful in getting the above message on UART with this baudrate.
Thank you for your help
Re: AT and IoT_Demo firmware not functioning
Postby costaud » Mon Nov 03, 2014 2:29 am
As far as I know, this print log is mostly caused by the spi flash r/w mode mismatching.
The default setting is that the spi flash port works in quad r/w mode , if the flash do not support this mode , the chip can not boot up correctly.
Please use the latest download tool and set the spi dout mode in config panel.
If it works , check the flash datasheet and confirm whether it supports quad r/w mode.
- download_tool.png (62.35 KiB) Viewed 17757 times
Postby Fadi » Mon Nov 03, 2014 4:37 am
I got an esp8266 esp-01 module already has onboard flash..etc
And if I flash 0.922 firmware using xtcom it works.
Are you sure i need to use this tool ? But what should I put for the clock?
Postby muris » Mon Nov 03, 2014 10:33 pm
Postby Fadi » Mon Nov 03, 2014 10:46 pm
muris wrote:Where can I download the ESP FLASH DOWNLOAD TOOL for Windows?
http://www.electrodragon.com/w/Wi07c
towards the end of the page, you should see a link to XTCom tool.
there is also another option, espTool.py (but needs python installed on windows, google for it easy to find I don't have the link handy)
Postby muris » Mon Nov 03, 2014 11:26 pm
Here is the screenshot:
download/file.php?id=21
Postby Fadi » Tue Nov 04, 2014 12:05 am
I can't find the link right this second sorry.
PM me your email, I can send it to you, but again it didn't work for me.
