SDK 1.5.3 and liblwip_536
tvoneicken
Postby tvoneicken » Thu Apr 28, 2016 10:12 am
SDK 1.5.3 is missing liblwip_536.a, can you please provide it? It's pretty critical in memory constrained firmwares that need to support many connections. Thank you!
(Is there a reason you're leaving out of every SDK version?)
Re: SDK 1.5.3 and liblwip_536
Postby ESP_Faye » Wed May 04, 2016 5:33 pm
We are going to release the new version SDK, ESP8266_NONOS_SDK_V1.5.4 which will have the liblwip_536.
george
Postby george » Sun May 08, 2016 4:16 pm
我在乐鑫的淘宝官网上面购买了你们原厂的开发板,经过不懈的努力,终于使开发板设备连接到了espressifIOT,但是,这条给plug设备创建定时器的命令: curl -H "Authorization: token HERE_IS_THE_DEVICE_KEY" -d '{"timers":[{"type":"LOOP_PERIOD","period":"minute","time":1,"action":"action"}]}' https://iot.espressif.cn/v1/device/time ... ormat=true
却无法到达设备,虽然从服务器返回的结果显示是OK的,但是plug设备却从未收到任何timer设置指令,请问这是怎么回事,这个问题困扰了我一个多月时间了,请你们帮我解决一下,我给你们跪下了!!!!
还有,你们有没有官方的开发者技术交流群,没有的话建议创建一个,有的话告诉我,反馈问题实在太不方便了,还有我发现了你们官方文档有几处错误的地方,请你们协助更正一下!!!!
Postby ESP_Faye » Mon May 09, 2016 11:11 am
您好,
请试一下
curl -H "Authorization: token HERE_IS_THE_OWNER_KEY" -d '{"timers": [{"type": "LOOP_PERIOD", "period": "second", "time": "30", "action": "action"}]}' http://iot.espressif.cn/v1/device/timers/?deliver_to_device=true
您在开发中遇到任何问题,都可以咨询我们的技术支持邮箱 feedback@espressif.com。
对于文档您有哪些修改建议,也可以直接向我们提出。
感谢您对 ESP8266 的关注!
tvoneicken
Postby tvoneicken » Sat May 14, 2016 1:01 pm
Thanks! I'm eagerly awaiting 1.5.4 :-)
Postby ESP_Faye » Tue May 24, 2016 2:42 pm
Please have a try with the attachment based on ESP8266_NONOS_SDK_V1.5.4.
liblwip_536_for_ESP8266_NONOS_SDK_V1.5.4.zip
(108.37 KiB) Downloaded 828 times
