single AT BIN file ..
Postby phil31 » Tue Feb 17, 2015 9:56 pm
well, why not provide a single BIN file to flash instead of different BIN to place at different offset ?
this avoid confusing for sure !
a single file, starting every time at offset 0x00000 will be usefull for next release .. nope ?
thanks, regards
Re: single AT BIN file ..
Postby rudi » Fri Feb 20, 2015 2:04 am
phil31 wrote:i already test it on different version
it was never successful
you confirm that this button work right ?
thanks
yes - works fine - which version you are use?
cheers
問候飛出去的朋友遍全球魯迪
Postby phil31 » Sun Feb 22, 2015 2:08 am
i just try to combine bin files with "ESP FLASH DOWNLOAD TOOL V0.8" (the file is "frame_test.exe" 8304567 bytes = 7.91MB size )
i take bin files from AT-0.22.b.1.0 folder :
AT-0.22.b1.0\blank.bin ==> 0x3E000
AT-0.22.b1.0\boot_v1.2.bin ==> 0x00000
AT-0.22.b1.0\user1.new.bin ==> 0x1000 ( i try too with the file "user1.512.new.bin")
AT-0.22.b1.0\blank.bin ==> 0x7E000
i click on "combine" then i upload the "target.bin" file with the esp8266_flasher.exe.
it fail at the end :
Writing at 0x0007fc00... (96 %)
Writing at 0x00080000... (96 %)
Failed to write to target Flash
then when i reboot, i obtain this message from the bootloader ( at 75000bps) :
ets Jan 8 2013,rst cause:1, boot mode:(3,7)<CR><LF>
<CR><LF>
load 0x40100000, len 816, room 16 <CR><LF>
tail 0<CR><LF>
chksum 0x8d<CR><LF>
load 0x3ffe8000, len 788, room 8 <CR><LF>
tail 12<CR><LF>
chksum 0xcf<CR><LF>
ho 0 tail 12 room 4<CR><LF>
load 0x3ffe8314, len 288, room 12 <CR><LF>
tail 4<CR><LF>
chksum 0xcf<CR><LF>
csum 0xcf<CR><LF>
<CR><LF>
2nd boot version : 1.2<CR><LF>
SPI Speed : 40MHz<CR><LF>
SPI Mode : QIO<CR><LF>
SPI Flash Size : 4Mbit<CR><LF>
jump to run user1<CR><LF>
<CR><LF>
get flash_addr error!<CR><LF>
user code done<CR><LF>and unfortunately, the AT firmware (at 115200bps) don't send me the "ready" message ...
Please, where i'm wrong ?
thanks
Phil
Edit -----------------------------------------------------------------------
i just download now the ESP FLASH DOWNLOAD TOOL V0.9.3.1 i try with the same previous offset : no file is generated when i click on "combine" !
Traceback : File "Panel_Combine.pyo", line 113, in OnButtonConbine
WindowsError: [Error 14] not enough memory for this operation 'combine'
i'm disappointed ..
Edit 2-----------------------------------------------------------------------
well i had some errors with the offset !
now i tried :
AT-0.22.b1.0\esp_init_data_default.bin ==> 0x7C000
i successful generate a "combine file" then i upload it with the flash downloader
when i boot the ESP8266, i receive :
<<ESC>c<ESC>d`<ETX>;l„<ETX>ÕMEM CHECK FAIL!!!<CR><LF>
ä{$Oÿ<CR><LF>
ready<CR><LF>
22/02/2015 22:35:08.509 [TX] - AT+GMR<CR><LF>
22/02/2015 22:35:08.513 [RX] - AT+GMR<CR>
<CR><LF>
AT version:0.22.b1.0<CR><LF>
SDK version:0.9.5<CR><LF>
<CR><LF>
OK<CR><LF>
seem working, but what is that "MEM CHECK FAIL!!!" message please ?
Postby ESP_Faye » Wed Feb 25, 2015 10:11 am
the "MEM CHECK FAIL!!!" problem has been resolved in esp_iot_sdk_v0.9.6_b1 http://bbs.espressif.com/viewtopic.php?f=7&t=205
please have a try ~
Postby phil31 » Thu Feb 26, 2015 4:50 am
please have a look to my trace.. it is the 0.22b1 !!
do you provide a new 0.22b1 with the SDK 0.9.6 ??
regards
edit -----------------------------------------------
just tried with the 0.22b1 / SDK0.9.6b1 : SAME message !!
<ESC>gŸ<SO>dlÛ"n<STX><EOT>Ÿg„'ãolŸ|<ESC>c<ESC>l`<ETX>{lŒ<ETX>ÕMEM CHECK FAIL!!!<CR><LF>
äsdGÿ<CR><LF>
ready<CR><LF>
25/02/2015 22:35:03.570 [TX] - AT+GMR<CR><LF>
25/02/2015 22:35:03.574 [RX] - AT+GMR<CR>
<CR><LF>
SDK version:0.9.6(b1)<CR><LF>
<CR><LF>
OK<CR><LF>
here it is the way i produce a single BIN file :
boot_v1.3(b3).bin 0x0
user1.512.new.bin 0x1000
blank.bin 0x7E000
all files coming from esp_iot_sdk_v0.9.6_b1 folders (bin and at folders)
did i do something wrong please ??
regards
Postby rudi » Thu Feb 26, 2015 10:52 pm
phil31 wrote:Faye,
regards
phil31 wrote:Hi,
hi
please have a try in 0.9.3
viewtopic.php?f=7&t=25
and report if you can reproduce again or solve yours with the last flash download tool version .
best wishes
rudi
btw
for interesset reason -
which module you take?
at market are several difference moduls with winbond / alternate flash chips and difference series
問候飛出去的朋友遍全球魯迪
