Wifi radio not working
systemsconnect
Postby systemsconnect » Wed Feb 18, 2015 6:58 pm
It seems our divider circuit connected to the ADC of the ESP8266ex has damaged the wifi radio. Our configuration is running at 10 seconds deep sleep interval and after waking up, the voltage of the battery is read from the ADC, wifi connects and sends the data over wifi and sleeps again.
The supply voltage has a maximum of 3.6V. To the ADC a divider circuit brings down the voltage lower than 1V. The divider circuit resistors R1 is 10MOhm a R2 is 2.7MOhm. The divider circuit is directly connected to the battery positive and ground.
Somehow, after running a couple of hours fine, the wifi fails to connect and it will never connect again (even after a power off and on).
I've tested multiple chips and all of them seems to be broken after a while. Everything else still works, so it does wakeup and goes to sleep again but it does not connect to wifi anymore. After flashing the firmware again it still does not connect. If I take an other ESP8266 chip with the same firmware it works.
Has somebody any idea what the problem could be?
Re: ADC damages Wifi radio?
Postby reaper7 » Wed Feb 18, 2015 8:07 pm
deep_sleep_set_option(1)RF_CAL after deep-sleep wake up, there will be large current.
before execute system_deep_sleep
systemsconnect
Postby systemsconnect » Wed Feb 18, 2015 8:49 pm
systemsconnect
Postby systemsconnect » Wed Feb 18, 2015 11:11 pm
If the ADC is not connected it's perfectly working all the time so the firmware seems OK.
systemsconnect
Postby systemsconnect » Thu Feb 19, 2015 9:30 pm
I don't know what te problem is.
Postby joostn » Fri Feb 20, 2015 5:24 pm
You might try erasing those blocks and filling with zeros.
systemsconnect
Postby systemsconnect » Fri Feb 20, 2015 11:41 pm
Please, can you explain why these address get corrupted and why did you think this address causes the problem?
systemsconnect
Re: Wifi radio not working
Postby systemsconnect » Tue Feb 24, 2015 5:17 pm
