MESH_DEMO from github
Postby CipiCips » Sat May 07, 2016 12:36 am
I have manage to compile MESH_DEMO from github provided by AlenXiao.
Now I am planning to implement that mesh with few devices that have esp8266 esp-07 connected via RX/TX to microcontroller. My goal is to send from server one data to every node and receive it via UART to the microcontroller.
After programming esp with corresponding files from MESH_DEMO I am unable to figure out how this work. Server from pyton is running and I can only see when something is connected to it.
Are there any guids how to implement something inside this demo, for example adding default baud rate ect.
Thx
Ivan
ESP_Alen
Re: MESH_DEMO from github
Postby ESP_Alen » Thu May 12, 2016 7:34 pm
CipiCips wrote:Hello,
Thx
Ivan
You can use AT to comunicate between MCU and ESP8266, and you can get AT demo from current non-os-sdk-v1.5.3:
viewtopic.php?f=46&t=2041#p6488
If you plan to use your own server to sent packet to all the node working in mesh, you just build mesh bcast packet, then send the packet to root node, the packet will been forwarded to every node.
Please refer to detail format of mesh packet:
https://github.com/espressif/ESP8266_ME ... r/document
ESP_Alen
Postby ESP_Alen » Fri May 13, 2016 7:03 pm
ESP_Alen
Postby ESP_Alen » Tue May 17, 2016 6:09 pm
CipiCips wrote:Dear Alen
thx for help, we will try to implement what we need and we will post all questions and problems here.
Any problem, please feel free to post it on BBS.
Postby CipiCips » Thu May 19, 2016 12:38 am
So far we have managed to compile mesh_demo from github repository.
We have flashed two esp-12 modules (one is root node one is client node) with generated files as instructed at README file.
Our question is how can we see is this working, we have run demo_server from mesh demo and all we got is this:
mesh server works
<__main__.MeshHandler instance at 0x0000000002259248>From serial monitor we got a lot of information for both esp modules
free heap:42856
recv entrance
mesh_json_proto_parser
len:27, data:{"req_key":"req_key_val"}
recv entrance
len:31, data:{"mcast":"18:fe:34:da:c0:b3"}
idx: 0, mac:e8:40:f2:47:0e:22
idx: 1, mac:18:fe:34:da:50:3a
recv entrance
len:31, data:{"mcast":"18:fe:34:da:50:3a"}
free heap:42856
recv entrance
recv entrance
len:31, data:{"bcast":"18:fe:34:da:50:3a"}
Regards
Ivan
Postby CipiCips » Thu May 19, 2016 7:39 pm
Is it possible to set baud rate to 9600 ?
We will try to modify our server to use mesh bcast packet. Is it possible to send string of 20 characters maximum to all nodes ? When node receive packet string of 20 characters is it possible to send that string over USART to MCU ?
Regards
Ivan
ESP_Alen
Postby ESP_Alen » Thu May 19, 2016 8:37 pm
CipiCips wrote:Dear Alen,
Regards
Ivan
1. Please use following statement to set serial baut ratio, we have merge the statements and push it on github.
uart_div_modify(0, UART_CLK_FREQ / 9600);
uart_div_modify(1, UART_CLK_FREQ / 9600);
2. The maximum length of mesh packet is 1300.
3. When node receive packet, it's feasible to send packet to MCU with USART.
Nikita Belyaev
Postby Nikita Belyaev » Thu May 19, 2016 10:10 pm
Can someone ask for this questions:
1) On which OSI layer does mesh protocols works?
2) How to create root node?
3) When I burned my esp8266 with mesh_demo from git, which kind of node I did? And how can I change user data?
4) Why I'm not able to change server IP? Be default its 0.0.0.0 7000. And when it started I cant see anything except "mesh server works"
There are more questions, but I cant go further without understanding of that things))
Thanks for your cooperation!
BR, Nik
