1. How i can increase range of ESP mesh? , because when i try it using esp-07 it only can receive data about max 17 meter. After ESP lost connection. And with only 50cm from router RSSI only read -50 is it normal? How i can achieve 100m range per hop like in your document?
2. Can i send data to ESP using demo_server.py? like to turn on and of Lamp etc. I am already try using chat socket server
#!/usr/bin/python
# chat_server.py
import sys
import socket
import select
HOST = ''
SOCKET_LIST = []
RECV_BUFFER = 1024
PORT = 7000
def chat_server():
server_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
server_socket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
server_socket.bind((HOST, PORT))
server_socket.listen(10)
# add server socket object to the list of readable connections
SOCKET_LIST.append(server_socket)
print "Chat server started on port " + str(PORT)
while 1:
# get the list sockets which are ready to be read through select
# 4th arg, time_out = 0 : poll and never block
ready_to_read,ready_to_write,in_error = select.select(SOCKET_LIST,[],[],0)
for sock in ready_to_read:
# a new connection request recieved
if sock == server_socket:
sockfd, addr = server_socket.accept()
SOCKET_LIST.append(sockfd)
print "Client (%s, %s) connected" % addr
broadcast(server_socket, sockfd, "[%s:%s] entered our chatting room\n" % addr)
# a message from a client, not a new connection
else:
# process data recieved from client,
try:
# receiving data from the socket.
data = sock.recv(RECV_BUFFER)
if data:
#print >>sys.stderr, 'Header "%s"' % binascii.hexlify(data[0:4])
broadcast(server_socket, sock,data)
else:
# remove the socket that's broken
if sock in SOCKET_LIST:
SOCKET_LIST.remove(sock)
# at this stage, no data means probably the connection has been broken
broadcast(server_socket, sock, "Client (%s, %s) is offline\n" % addr)
# exception
except:
continue
server_socket.close()
# broadcast chat messages to all connected clients
def broadcast (server_socket, sock, message):
for socket in SOCKET_LIST:
# send the message only to peer
if socket != server_socket and socket != sock :
try :
socket.send(message)
except :
# broken socket connection
socket.close()
# broken socket, remove it
if socket in SOCKET_LIST:
SOCKET_LIST.remove(socket)
if __name__ == "__main__":
sys.exit(chat_server())
and client to send data
# chat_client.py
#!/usr/bin/python
import sys
import socket
import select
import binascii
def chat_client():
if(len(sys.argv) < 3) :
print 'Usage : python chat_client.py hostname port'
sys.exit()
host = sys.argv[1]
port = int(sys.argv[2])
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.settimeout(2)
# connect to remote host
try :
s.connect((host, port))
except :
print 'Unable to connect'
sys.exit()
print 'Connected to remote host. You can start sending messages'
sys.stdout.write('[Me] '); sys.stdout.flush()
while 1:
socket_list = [sys.stdin, s]
# Get the list sockets which are readable
ready_to_read,ready_to_write,in_error = select.select(socket_list , [], [])
if sock == s:
# incoming message from remote server, s
data = sock.recv(1024)
if not data :
print '\nDisconnected from chat server'
sys.exit()
else :
#print data
sys.stdout.write(data)
else :
# user entered a message
msg = sys.stdin.readline()
data = str(msg).split('/')
print data
test = bytearray()
test[0:4]= binascii.unhexlify(data[0])
test[4:10]= binascii.unhexlify(data[1])
test[10:16]= binascii.unhexlify(data[2])
test[16:]= data[3]
data_sent = test[0:4] + test[4:10]+ test[10:16]+ test[16:]
print 'Payload: ' + binascii.hexlify(data_sent[0:])
s.send(data_sent)
sys.exit(chat_client())
and try send data like in demo_server.py that included : Header + Source + Target + Payload and still no luck.
thx for your help
Yudha
