RTOS SDK 1.4 Can't connect wifi
vaibhav93
Postby vaibhav93 » Mon May 16, 2016 4:27 am
Module
ESP-01 512KB
Where all seems to work fine in RTOS v1.3, I am not able to connect to wifi in 1.4,
405328> no 502_SBC found, reconnect after 1s
405429> reconnect
comes repeatedly.
I know the code is correct and bssid is also set to 0 like here http://bbs.espressif.com/viewtopic.php?f=31&t=228
In short, the smart_config example works in 1.3 and doesn't in 1.4
Re: RTOS SDK 1.4 Can't connect wifi
Postby ESP_Faye » Wed May 18, 2016 5:39 pm
Sorry that we can not reproduce your problem.
Could you provide your test code for debugging ?
Here is our test code.
void user_init(void)
    /* need to set opmode before you set config */
    struct station_config *config = (struct station_config *)malloc(sizeof(struct station_config));
   bzero(config, sizeof(struct station_config));
        sprintf(config->ssid, SSID);
        sprintf(config->password, PASSWORD);
        /* need to sure that you are in station mode first,
         * otherwise it will be failed. */
        wifi_station_set_config(config);
        free(config);
