About the espressif provided API questions!
PaulTsai111
Postby PaulTsai111 » Wed May 18, 2016 9:56 am
I am studying about the esp8266 provided NonRTOS SDK. API seems only with function declared in the header files and
use the function by calling the function. I did not see any details of the API. So how can I start using these APIs?
Can you give me a sample on how to test and correct using these APIs? This make me with obsession !!
Re: About the espressif provided API questions!
Postby ESP_Faye » Thu May 19, 2016 9:58 am
You can refer to the documentation 2C-ESP8266__SDK__API Guide.
And here is some sample codes http://bbs.espressif.com/viewforum.php?f=31.
PaulTsai111
Postby PaulTsai111 » Thu May 19, 2016 4:00 pm
Here is one simple test problem that I encoutered during monitoring the COM port terminals
I use the RTOS Version 1.4 SDK for running the simple demo code
as shown below.
after that I use ./gen_misc.sh to generate the user1.xxx.bin file
I use flash download tools to download the user1.xxx.bin file and bootv1.5.bin file
into the esp8266 IoT Refernce Compatible Board
After that , I turn off the power changed from Download Mode to Flash boot mode and power on
However, from the Serial Port Monitor tools Terminal View I can not see any correct
output from the terminal views
I am a little bit confused this result
I do not know why?
Is there any steps wrong?
zhijianli88
Postby zhijianli88 » Fri May 20, 2016 5:16 pm
you should configure you terminal baudrate to 74880
more details pls refer to the startup guide http://bbs.espressif.com/viewtopic.php?f=51&t=1023
PaulTsai111
Postby PaulTsai111 » Mon May 23, 2016 5:42 pm
After studying the Espressif Starting Guide , I changed the crystal frequecy to 40MHz and set the baud rate to 115200 when downloads the bin files to the IoT Ref Compatible Board and use COM terminal monitor to monitor the messages output (baud rate =115200) when IoT Ref Board in reboot flash mode . The output still shows the strange and unknown codes. I guess it may be due to the bin compiling file is with problem , or my IoT Ref Compatible Board does not match the output bin files. (I used the newest version of NONRTOS/RTOS SDK, but Board is old version).Espressif provides the newer version of boards but our company still use older version. Can you give me some help or suggestion ? online help ?
PaulTsai111
Postby PaulTsai111 » Tue May 24, 2016 9:25 am
The attached bin file is that I tried under the NON-RTOS V1.6 16_04_18 SDK Version. Please Check and Give Technique Help ! Thanks
- Attachments
- bin_file.rar
- (301.66 KiB) Downloaded 399 times
Postby ESP_Faye » Tue May 24, 2016 11:12 am
We tested your bin files, it works fine, it will try to connect to a router named "PaulTsai" after power on. Its baud rate is 74880.
Maybe because that your UART tool can not support baud rate 74880 ?
You can change the baud rate of ESP8266 by calling uart_init in user_init, refer to http://bbs.espressif.com/viewtopic.php?f=61&t=182.
PaulTsai111
Postby PaulTsai111 » Tue May 24, 2016 6:34 pm
After adding the uart_init function in my main functions, It shows that unknown type wrong messages, can you show me which header file should be included in the main files ? The attached
file is my user_main.c files. please check !
esp8266@esp8266-VirtualBox:~/ESP8266_NONSDK_V1.5.3_16_04_18/ESP8266_NONOS_SDK/prac3$ ./gen_misc.sh
gen_misc.sh version 20150511
enter(0/1/2, default 2):
1
boot mode: new
enter (0/1/2, default 0):
1
generate bin: user1.bin
enter (0/1/2/3, default 2):
3
spi speed: 80 MHz
enter (0/1/2/3, default 0):
3
spi mode: DOUT
0= 512KB( 256KB+ 256KB)
2=1024KB( 512KB+ 512KB)
3=2048KB( 512KB+ 512KB)
4=4096KB( 512KB+ 512KB)
5=2048KB(1024KB+1024KB)
6=4096KB(1024KB+1024KB)
2
spi size: 1024KB
spi ota map: 512KB + 512KB
start...
make[1]: Entering directory `/home/esp8266/ESP8266_NONSDK_V1.5.3_16_04_18/ESP8266_NONOS_SDK/prac3/user'
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -DLWIP_OPEN_SRC -DPBUF_RSV_FOR_WLAN -DEBUF_LWIP -I include -I ./ -I ../../rom/include -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include user_main.c
make[1]: Leaving directory `/home/esp8266/ESP8266_NONSDK_V1.5.3_16_04_18/ESP8266_NONOS_SDK/prac3/user'
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -DLWIP_OPEN_SRC -DPBUF_RSV_FOR_WLAN -DEBUF_LWIP -I include -I ./ -I ../../rom/include -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../../driver_lib/include -o .output/eagle/debug/obj/user_main.o -c user_main.c
user_main.c:274:11: error: unknown type name 'UartBautRate'
uart_init(UartBautRate uart0_br, UartBautRate uart1_br)
user_main.c:274:34: error: unknown type name 'UartBautRate'
make[1]: *** [.output/eagle/debug/obj/user_main.o] Error 1
make: *** [.subdirs] Error 2
- Attachments
- user_main.rar
- (2.51 KiB) Downloaded 407 times
zhijianli88
Postby zhijianli88 » Fri May 27, 2016 11:35 am
PaulTsai111 wrote:Hi Espressif:
Hi, Espressif
Does the physical crystal effect this setting ?
Assume physical crystal is 26MHz, Can I set the crystal frequecy to 40MHz at the flash tools ?
