[SDK Release] ESP8266_NONOS_SDK_V1.5.4_16_05_20
Postby ESP_Faye » Fri May 20, 2016 8:27 pm
ESP8266_NONOS_SDK_V1.5.4_16_05_20 Release
Important Links
Here are the links for this SDK release (version ESP8266_NONOS_SDK_V1.5.4_16_05_20):
  1. Download Related Documentation
  2. Bug Bounty Program
Release Notes
  1. The return value of system_adc_read is wrong.
  2. The current is too high in light sleep mode.
  3. The ESP8266 maybe reset if connected to a special router.
Optimization:
  1. Updated libphy.a to version 972.
  2. Updated libpp.a to version 10.1, revised issues about frequency offset and sleep mode.
  3. Optimized IGMP function.
  4. Optimized DNS function.
  5. Optimized WPS function.
  6. Optimized DHCP server function.
  7. Optimized wifi_station_get_connect_status function.
  8. Revised the issue that API system_adc_read and system_get_vdd33 may return wrong value.
  9. Optimized API:
    bool espconn_secure_ca_enable(uint8 level, uint32 flash_sector);
    bool espconn_secure_cert_req_enable(uint8 level, uint32 flash_sector);
Added APIs:
  1. system_adc_read_fast: ADC fast sampling.
  2. wifi_fpm_auto_sleep_set_in_null_mode: set whether enter modem-sleep mode or not when WiFi is in NULL_MODE.
Known Issue:
  1. espconn_send returns OK of sending UDP data, even if ESP8266 station disconnects to the AP.
AT_v1.1 Release Note:
Notice:
Optimization:
  1. Optimized the behavior of writing Flash.
  2. Optimized DHCP server function.
  3. Updated command AT+SAVETRANSLINK to save domain name.
Have fun!
ESP8266_NONOS_SDK_V1.5.4_16_05_20发布
相关下载
    以下是最新SDK的相关下载链接 (版本 ESP8266_NONOS_SDK_V1.5.4_16_05_13):
  1. 文档下载链接。
  2. 您可以继续参与 Bug Bounty 计划。
发布说明
修正问题(符合乐鑫 Bug 赏金计划):
  1. system_adc_read 返回值异常。
  2. light sleep 模式下电流较高。
  3. 连接特殊路由器可能导致系统重启。
优化:
  1. 更新 libphy.a 到 972 版本。
  2. 更新 libpp.a 到 10.1 版本,解决部分频偏及休眠问题。
  3. 优化 IGMP 功能。
  4. 优化 DNS 功能。
  5. 优化 WPS 功能。
  6. 优化 DHCP server 功能。
  7. 优化 wifi_station_get_connect_status 函数。
  8. 修正 system_adc_read、system_get_vdd33 返回值异常的问题。
  9. 修改 API
Added APIs:
  1. system_adc_read_fast: ADC 快速采样
  2. wifi_fpm_auto_sleep_set_in_null_mode: 设置 Null Mode 模式下,是否自动进入 modem sleep
AT_V1.1 Release Note:
注意:
AT_v1.1 更新说明:
优化:
  1. 优化 AT 固件写 Flash 的行为。
  2. 优化 DHCP server 功能。
  3. 新增 AT+SAVETRANSLINK 对保存域名的支持。
ESP8266_NONOS_SDK_V1.5.4_16_05_20.zip
(3.1 MiB) Downloaded 94160 times
Ilove8266
Re: [SDK Release] ESP8266_NONOS_SDK_V1.5.4_16_05_20
Postby Ilove8266 » Mon May 30, 2016 11:26 am
日前有一部分用户反馈在使用 Eclipse 对最新的 SDK 默认编辑报错。
解决方案如下:
将固件根目录下的driver_lib文件夹(最新固件中新增的)拷贝到 app 文件夹中就可以正常编译了,注意目录结构
Someone feedback us that when they using Eclipse to compile latest SDK, there is error.
Please copy the driver_lib folder (newly added in latest SDK) under the root to the app folder. Then the compiling will be normal. Please pay attention to the folder structure.
Postby ESP_Faye » Mon Jun 06, 2016 8:46 pm
Till 2016-06-07, ESP8266_NONOS_SDK_V1.5.4_16_05_20 is the latest non-OS SDK. ESP8266_NONOS_SDK_V1.5.3.1 is just a middle version solved several bugs based on ESP8266_NONOS_SDK_V1.5.3.
截止到 2016-06-07,ESP8266_NONOS_SDK_V1.5.4_16_05_20 才是最新的非 OS SDK。ESP8266_NONOS_SDK_V1.5.3.1 只是一个中间版本,基于 ESP8266_NONOS_SDK_V1.5.3 解决了部分已知问题。
