Is there any way to disable the bootloader dumping startup information on UART? Should I use UART1 instead?
I am going to make a bridge (connect) ESP8266 to XBEE and this bootloader information is being transferred to XBEE on startup
Regards,
Muris
Postby muris » Sun Nov 02, 2014 4:35 pm
Postby costaud » Mon Nov 03, 2014 3:26 am
#define FUNC_U0CTS 4
#define FUNC_U0RTS 4
void user_init(void)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, FUNC_U0CTS);//CONFIG MTCK PIN FUNC TO U0CTS
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, FUNC_U0RTS);//CONFIG MTDO PIN FUNC TO U0RTS
SET_PERI_REG_MASK(0x3ff00028 , BIT2);//SWAP PIN : U0TXD<==>U0RTS(MTDO) , U0RXD<==>U0CTS(MTCK)
}Postby muris » Mon Nov 03, 2014 3:29 am
Postby costaud » Mon Nov 03, 2014 11:20 pm
muris wrote:Ok, thank you very much for this.
Also, where can I download the latest "Download Tool" to flash the chip? I am currently using the python version... (I saw your screenshot on another post).
Postby muris » Tue Nov 04, 2014 3:24 pm
Postby DhruvAcharya » Wed Nov 23, 2016 8:11 pm
//The setup function is called once at startup of the sketch
void setup()
Serial.begin(115200);
// The loop function is called in an endless loop
void loop()
for(uint8_t i=0;i<3;i++)
Serial.write(i);
delay(1000);
00 01 02 00 01 02 00 01 02 00 01 02Code: Select all
void setup()
// Swap serial port to continue on other uart.
Serial.swap();
void loop()
Serial.write(i);
delay(1000);
01 02 01 02 01 02 01 02Users browsing this forum: No registered users and 311 guests
