Establishment problems
Postby blax » Tue May 31, 2016 8:58 pm
What does 2 in MSH_2 prefix indicates? Completly new network?
ESP_Alen
Re: Establishment problems
Postby ESP_Alen » Wed Jun 01, 2016 3:10 pm
blax wrote:Hello. I have same image on all devices https://imgur.com/a/otJBI Why other nodes dont join mesh? This behaviour is random and number of nodes that joined mesh varies.
1. Please use clean version of mesh demo on github.
2. MSH_2 means the current device has join the mesh network, and works on second layer.
3. There are more than one root device working in mesh network, I don't know what's your scenario.
Could you descript the detail information about your scenario.
Postby blax » Fri Jun 03, 2016 7:37 pm
Now it seems that my 4 of 5 nodes are connecting well. It takes a bit to much time to establish network, but its ok for now.
free heap:40224
recv entrance
mesh_none_proto_parser
root's mac:5c:cf:7f:0b:9b:0c
idx: 0, mac:5c:cf:7f:0b:9b:0c
idx: 1, mac:5c:cf:7f:12:1f:09
idx: 2, mac:18:fe:34:d6:32:d3
idx: 3, mac:5c:cf:7f:15:aa:6d
recv entrance
mesh_json_proto_parser
len:27, data:{"req_key":"req_key_val"}
Now problem is with the last device(always the same one). It cant join the mesh. This is output from it
sssid:MESH_D_1_0B9B0C, ssid:MESH_D_1_0B9B0C, set:1, sbssi:5e:cf:7f:0b:9b:0c bssid:5e:cf:7f:0b:9b:0clast:0
f r0, espconn_mesh_scan_done connect MESH_D_1_0B9B0C
scandone
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f -180, scandone
f r0, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 0 (2)
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 0 (2)
f -180, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
state: 5 -> 0 (0)
rm 0
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (0)
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f -180, scandone
f r0, scandone
f r0, scandone
scandone
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f -180, scandone
f r0, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f -180, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
f -180, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
f r0, scandone
scandone
f 0, scandone
f r0, scandone
f r0, scandone
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 0 (0)
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (0)
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
f -180, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
f -180, scandone
f r0, scandone
f r0, scandone
scandone
reconnect
f 0, free heap:44328
mesh is busy
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
no mac in current mac list
mcast get root fail
mesh is busy
free heap:44328
mesh is busy
bcast mesh is busy
free heap:44328
mesh is busy
mesh is busy
free heap:44328
mesh is busy
mcast get root fail
free heap:44328
mesh is busy
bcast mesh is busy
mesh is busy
free heap:44328
mesh is busy
mcast get root fail
free heap:44328
mesh is busy
f r0, scandone
bcast mesh is busy
mesh is busy
free heap:44328
mesh is busy
Any advice? Thanks.
ESP_Alen
Postby ESP_Alen » Mon Jun 06, 2016 11:22 am
blax wrote:I always use the latest code from your github. Problem was that the wifi network analyzer can't correctly scan this type of network so I started to use serial for debug. For now I am just trying to run mesh demo in the way its described in a readme with a plans to use it in a sensor network.
Now it seems that my 4 of 5 nodes are connecting well. It takes a bit to much time to establish network, but its ok for now.Code: Select all
free heap:40224
recv entrance
recv entrance
We modify the beacon and probe-response, you can just scan root device, but the other device is not visible to user.
ESP_Alen
Postby ESP_Alen » Mon Jun 06, 2016 11:25 am
blax wrote:Now problem is with the last device(always the same one). It cant join the mesh. This is output from itCode: Select all
scandone
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f -180, scandone
f r0, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 0 (2)
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 0 (2)
f -180, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
state: 5 -> 0 (0)
rm 0
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (0)
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f -180, scandone
f r0, scandone
f r0, scandone
scandone
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f -180, scandone
f r0, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f -180, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
f -180, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
f r0, scandone
scandone
f 0, scandone
f r0, scandone
f r0, scandone
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 0 (0)
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (0)
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
f -180, scandone
f r0, scandone
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
f 0, scandone
f -180, scandone
f r0, scandone
f r0, scandoneCode: Select all
scandone
reconnect
mesh is busy
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (4)
mcast get root fail
mesh is busy
free heap:44328
mesh is busy
bcast mesh is busy
free heap:44328
mesh is busy
mesh is busy
free heap:44328
mesh is busy
mcast get root fail
free heap:44328
mesh is busy
bcast mesh is busy
mesh is busy
free heap:44328
mesh is busy
mcast get root fail
free heap:44328
mesh is busy
f r0, scandone
bcast mesh is busy
mesh is busy
free heap:44328
mesh is busy
Any advice? Thanks.
Please paste the complete log after device powers on.
